Drive by Wire TAC Pedals
Old Mar 10, 2011 | 07:07 PM
Bobby G's Avatar
Default Drive by Wire TAC Pedals
Does anyone know what pedals work with which TAC moduals, I have a 2007 LQ4 and the TAC and Pedal but the Pedal will not work and I can not cut it its plastic
Old Mar 10, 2011 | 08:05 PM
crosstraining's Avatar
https://ls1tech.com/forums/conversio...-assembly.html
https://ls1tech.com/forums/conversio...gas-pedal.html
https://ls1tech.com/forums/conversio...can-i-use.html
Old Mar 10, 2011 | 08:14 PM
Bo185's Avatar
Truck DBW components
The TAC module has two connections, one for the pedal harness..other hooks into main engine harness there are two styles the 9-pin connector the later ones are 6-pin.
TAC modules have to match up to the year range of the PCM AND the throttle body.
03-06 TAC module works with 03-06 truck TB and 03-06 PCM (BLUE/GREEN connectors)
01-02 TAC module works with 01-02 truck TB, 97-04 Vette TB, and 01-02 PCM (BLUE/RED connectors).
03-06 TAC modules have an aluminum mounting base, 01-02 TAC modules are all black plastic including the mounting base.
The newer 07 up take a different pedal assembly.
Should look like this
Old Mar 10, 2011 | 08:17 PM
This is some great info. If it is not it needs to be in FAQ
Old Mar 6, 2013 | 01:17 PM
ace32x's Avatar
bumping an old thread. i have an 01 vette ecu im using for my drive by wire ls6 swap. i have a pedal and tac module unit from an 05 5.3L truck. im getting these codes p1120 p1220 p1221 p1515 p1516 p1518 and i have a feeling its pedal and tac module related. judging by the info posted above im going to say that theyre not interchangeable and i need a new set up but thought i would check. also running a nick williams 102 throttle body with the racetronix adapter harness.
Old Mar 6, 2013 | 05:23 PM
psiconversion's Avatar
LS1Tech Sponsor
What does nick Williams say? I'm pretty sure you have to use the vette tac module and pedal with those.
Jon
PSI
Old Mar 6, 2013 | 06:03 PM
ace32x's Avatar
Jon
PSI
i didnt contact them as i figured itd be a better question for the guys who made my harness but theyre kind of iffy on it aswell. basing it off what i can find the 05 truck pedal and tac use a 3 sensor set up as to the 97-04 vettes use a 2 sensor and i have an 01 vette ecu. so im going to overnight a pedal and tac from a vette tomorrow and put that in and see if it solves it. im praying otherwise im out 500 for the pair XD
Old Mar 7, 2013 | 06:37 AM
LS1Tech Sponsor
Keep in mind that the harness between the Truck TAC and Pedal is Different from the Vette TAC and Pedal. Good Luck.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Mar 7, 2013 | 10:44 AM
ace32x's Avatar
Jon
PSI
i believe harness i have is set up for a vette ecu and pedal and tac, its a custom harness from speed scene wiring. but it has the truck plugs on it so im going to have to see where i can source 2 male plugs that match the vette harness tac and pedal plugs
Old Mar 7, 2013 | 11:39 AM
ace32x's Avatar
thanks on giving me a hand and working with me on that connector jon! i would have had you guys make me the harness had i known about you a few months ago!
Old Mar 7, 2013 | 05:09 PM
omc8's Avatar
I need to know what passenger car pedal will work with 2007+ nnbs Silverado ecm and harness ?
Old Mar 7, 2013 | 07:05 PM
LS1Tech Sponsor
Vette pedal will work if it is configured for it.
Jon
PSI
__________________
Ebay Store
Old Mar 8, 2013 | 03:44 PM
Bo185's Avatar
Pretty much any 6 pin one will work as long as its pinned right for that peda.l I would have to look to see if they are all pinned similarly to the GMT900 trucks.
So most the 07-up GM 6 pin plug pedals will work pretty much out of most cars and SUV's.
Lokar makes one that will work as well. But I think its only is the pedal and you have to provide the sensor then remove the plastic pedal and install their metal one on the stock sensor.
Old Mar 11, 2013 | 02:13 PM
omc8's Avatar
I have a pedal from a 2007 Pontiac G6 that I would like to use. And you are right the NNBS truck is 6 pin and G6 pedal is 6 pin , but they are different sensors. Can the G6 be repinned to work with truck ecm .
Old Mar 11, 2013 | 05:56 PM
Bo185's Avatar
Just look at the pinouts and see if they can simply be swapped.
The E38 truck GMT 900 pinouts of pedal plug
ECM Pedal
Pin 36 TN 5-Volt Reference 1 - APP Sensor Pin C
Pin 32 L-BU APP Sensor 2 Signal - APP Sensor Pin B
Pin 23 PU Low Reference - APP Sensor Pin A
Pin 56 WH/BK 5-Volt Reference 2 - APP Sensor Pin D
Pin 29 D-BU APP Sensor 1 Signal - APP Sensor Pin E
Pin 30 BN Low Reference - APP Sensor Pin F
Old Mar 12, 2013 | 09:41 AM
omc8's Avatar
ECM Pedal
Thanks Bo ,
I will check those against the the G6 pins , Can I get those from alldata ?
Old Mar 17, 2014 | 12:46 PM
240sx940's Avatar
03-06 TAC modules have an aluminum mounting base, 01-02 TAC modules are all black plastic including the mounting base.[/IMG]
Sorry to revive an old thread but I've looked and can't find the info.
The 97-03 Corvette PCM connectors are (BLUE/RED) and the 04 Corvette PCM plugs are (BLUE/GREEN). Should the 04 Vette TB be with the 03-06 TAC since the PCM has BLUE/GREEN connectors? The reason I ask is I have a engine harness and PCM from an 04 Vette and the connectors are BLUE/GREEN. Thanks.
Old Mar 20, 2014 | 12:24 PM
240sx940's Avatar
No one?
