LSX In 91 C4 Corvette My Swap
#181
I just finished putting it all back together.
It's dark and I'm tire so I'm going to wait till morning ck all the fluids and look it over very well before I crank it up.
#183
Congrats...lot's of work but you are certainly on the home stretch.
#184
#186
If you plan to constantly change things...you're better off learning for yourself. Otherwise you'll be out X dollars every time you make a major change.
If you plan to leave it alone...get someone else to tune it and be done.
LSEdit isn't cheap...nor any of the other programs to change the computer. Last I remember seeing it was around $1300 for the software...so that would be your target. If you planned to do more than 3 or 4 changes...you'll break even buying the software and doing it yourself.
Can't wait to see video when it's running 100%...sounds good already.
#187
Two schools of thought on that...
#189
hptuner is great.but,it doesn't come with an a to b roadmap.you have to spend a fair amount of time reading and learning. they most likely have a few lawyers telling them about the liability of screwing with emissions hardware and such. the learning itself is fun (at least for me).
#191
Thanks I have been thinking about covers but I'm not sure yet. Post some pictures when you get them on.
#193
I need to replace a shif solenoid but here is a little teaser.
LSX corvette C4 LS1 swap take off MS3 cam - YouTube
What did it dyno at the tuners? Did your tuner have a dyno? Curious to see what that set up is making, I was considering stroking a 5.3 as well but to 383 ci. You did it do an LS1 spec 347 rotating assy. I'm assuming?
#194
Its an LM7 bored to 5.7, ls1 heads and a MS3 cam. It dynoed at 370RWHP before it was put in the car. I have not dynoed the car yet but It was lean all over when I had it street tuned so it could be closer to 400RWHP now.
#195
Lots of awesome info here brother! Really glad I found the thread.
One more question for you. (You're probably getting tired of them, lol) A few pages back there was talk of the truck motor's crank being too long. Is this true? I was just about to pull the trigger on a truck engine, because its cheaper, and seems to be stronger than the aluminum block. But my issue is I won't be able to (financially) afford a rebuild too. Would I be better off just going with the ls1 I found? Thanks again for all your help! You're a gentleman, and a Scholar. h
#196
I hate to steer you wrong. I think there is a version of a truck crank that is too long but I have to look into it.
#197
So I did find an answer. I know your's is done but may be helpful to others. Here's a qoute from GM.
"The crankshafts are mostly interchangeable, but the snouts on LS7 and LS9 crankshafts are approximately 1-inch longer to accommodate their two-stage oil pumps that work with the engines' dry-sump oiling systems. These forged crankshafts can be used on wet-sump engines by using a few specific components and/or modifications."
Read more: http://www.gmhightechperformance.com...#ixzz2eZT9R53I
Also found a speed guy in my area, named "Ellis Groo". Do you think his parents knew 50 years later he would be the "LS Guru"? He was very helpful and gave me a lot of places to get parts. So a shout out to "Speed Secrets" Of Monroe, Wa. http://www.speedsecretsefi.com/index.htm
Here's a couple links for a th700r4 tailhousing, and 4l60e adapter. http://atransmission.info/700r4-corv...using-new.html and http://www.advanceadapters.com/downloads/50-0405E.pdf
Im leanring a lot, but still feel Ive only scratched the surface. Still pretty unsure of the wiring. Maybe I'll send it to you since you enjoy it so much! Lol! Peace brother. h
#198
#199
That is new info to me. Thanks! Do you have a part number, or engine code? So I dont get that one. Peace. h
#200
