TT LS Fox
Old Oct 10, 2012 | 09:52 AM
  #101
LS1PUNK's Avatar
No its not getting tuned yet, not even sure who Im gunna take it too.
Still got to some things to take care of before I get to that point.
I would offer to come help but Im dropping my bro off at the airport then got some other business to take care.
Old Nov 10, 2012 | 10:16 AM
  #102
LS1PUNK's Avatar
Got all the lil bugs worked out this past week.
Only 3 things I can think of till its done:
1. Alignment
2. Fix a few leaks
3. Get it tuned.
Old Nov 10, 2012 | 10:26 AM
  #103
LILHEMI's Avatar
1. Alignment
2. Fix a few leaks
3. Get it tuned.
im excited for you !!!
Old Nov 16, 2012 | 12:13 AM
  #104
LS1PUNK's Avatar
Been messing with a couple things this past week and decided to take it around the block today. Around the 4:30 mark I was rolling into the throttle and clicked 2nd gear and it went from -4lbs of vacuum to 12lbs of boost FAST and I backed out of it. It felt pretty good but I dont want to be picking pieces of the bottom end up off the curb either.
http://www.youtube.com/watch?v=Lf_FI...ature=youtu.be
Old Nov 16, 2012 | 10:23 AM
  #105
Capown's Avatar
What front brake setup did you go with? I have brakes off I think a 96 or 97 SN95 and The calipers hit my Welds with a 1/4" spacer.. Im banging my head I don't remember what I did on my old coupe.
Old Nov 16, 2012 | 10:28 AM
  #106
1bad03snake's Avatar
you need to get longer wheels studs and run a bigger spacer. My race start wheels fit without a spacer but its close
Old Nov 16, 2012 | 11:42 AM
  #107
Capown's Avatar
Aight maybe 1/2"?? Or should I buy a hub centric one that bolts down?
Old Jan 1, 2013 | 04:45 PM
  #108
LS1PUNK's Avatar
I don't really have a big update but I ordered HP Tuners awhile back and it finally showed up.
During the wait for it to show up I started looking around at other engine management systems and followed up on the Holley EFI setups.
Long story short, HP Tuners is on its way back and Ill be ordering Holley's EFI Dominator setup as soon as I get back from my next hitch.
Between all I/O capabilities, auto tune feature, boost controller, data logging, etc. It was a no brainer.
That being said, anybody know some one looking for a good kidney?
Old Jan 22, 2013 | 12:07 PM
  #109
jfisher's Avatar
Updates?
The Holley Dominator is really by far the cheapest option out there when compared to the other big 3. Just sucks because it sounds like you already did all the wiring work to get the car running a different way.
Old Jan 28, 2013 | 10:15 PM
  #110
LS1PUNK's Avatar
Originally Posted by jfisher
Updates?
I just got off the rig today and found this in my room.
I agree.
If they would have finished the boost controller before they released it and had the coil issue fixed a lot sooner I would of already went with this setup.
It does suck some to have to strip everything out and start over but its too late to stop now.
Old Jan 30, 2013 | 09:31 AM
  #111
jfisher's Avatar
I agree.
Well maybe you can sell your old harness and recoup some of your cost. I would be interested if the Holley HP weren't so damn "cheap" and simple to use.
Old Jan 30, 2013 | 10:41 AM
  #112
LS1PUNK's Avatar
Ture, they aren't as cheap as hp tuners or EFI live but I think its worth the $.
Old Feb 10, 2013 | 10:29 AM
  #113
Adam253's Avatar
Dude yourcar is bad a$$!! What trans crossmember did you use? Going to use the same gauge cluster.
Old Feb 10, 2013 | 01:20 PM
  #114
LS1PUNK's Avatar
Thanx man.
The crossmemeber is the the AJE one, got that and the k-memeber from jegs.
Old Feb 10, 2013 | 05:45 PM
  #115
87lsttop's Avatar
Ive heard that Bobby over at clear lake speed is pretty good at tuning these motors. From what I understand Jake is no longer tuning and is sending all his work to Bobby now. He may be an option for ya.
Old Feb 10, 2013 | 09:20 PM
  #116
LS1PUNK's Avatar
I dunno about using bobby, Ive heard a few things about the way he tunes that I dont agree with.
Plus I bought the dominator for the sole reason to learn how to do it my self.
Old Feb 11, 2013 | 04:24 AM
  #117
87lsttop's Avatar
Really all the people Ive heard from say hes pretty good. Hell there aint no telling. I was into all that tuning stuff when I had the tweecer for the fox pcm but ended up racking up countless hours messing with it. Its awesome after you learn what affects what.
Old Feb 12, 2013 | 07:31 PM
  #118
I dont think bobby tunes speed density. I'm using KP racing (Joe Honeycut)
Old Sep 22, 2013 | 09:04 PM
  #119
LS1PUNK's Avatar
Been a LONG time since Ive updated this.
Between work, general life, moving, and my dad passing away it has taken me a while to get **** done to the car.
At first I kept finding more and more wiring issues that I wasn't happy/comfortable with so I stripped the car of everything and fixed everything I could find.
I ended up making my own fuse and relay panel, rewired everything and cleaned it all up.
While I had everything out I wanted to make everything as simple as possible. Instead of using the Florida 5.0 cluster and running a set of sensors for it and another set for the Holley I decided to sale the Florida 5.0 cluster and pickup a Racepak Iq3. I can share everything from the Holley to the Rackpak via 1 cable, STUPID SIMPLE.
Reinstalled the interior and took it out for a test drive.
That pretty much sums everything up so far, hope to get a few things ironed out next time Im home and get this thing tuned and on the street/track.
Old Sep 22, 2013 | 09:17 PM
  #120
Bowtiedford's Avatar
wiring can be a nightmare, looks like you have it under control. Looks super clean.
