TT LS Fox
Old Sep 22, 2013 | 09:31 PM
  #121
LS1PUNK's Avatar
Thanx. Wiring has held this car up for a LONG time.
I was going to send it off and get it done but decided to read up on it and do it myself, just took me awhile.
Old Sep 23, 2013 | 08:36 AM
  #122
Zmg00camaross's Avatar
Probably my favorite fox on here. Just sell it to me haha!
Old Sep 23, 2013 | 03:58 PM
  #123
Tig's Avatar
Tig
Wow, amazing job on the fuse and relay panel.
Great job
Old Sep 24, 2013 | 07:31 PM
  #124
LS1PUNK's Avatar
Thanx guys.
Zmg00camaross- everything is for sale for the right price.
Old Sep 24, 2013 | 08:00 PM
  #125
Zmg00camaross- everything is for sale for the right price.[/QUOTE]
This is true
Old Oct 10, 2013 | 10:54 AM
  #126
LS1PUNK's Avatar
Got back in monday and addressed a few issues, took it out last night for a little bit and started wokring on the tune.
Waiting for a few more parts to show up but Im READY for this thing to be done!
Old Oct 10, 2013 | 03:27 PM
  #127
MustangLS's Avatar
Looks like you had your hands full on the wiring job but it came out great. I like your boost solenoid set up I plan on doing something very similar to that.
Old Oct 10, 2013 | 07:42 PM
  #128
LS1PUNK's Avatar
Thanks.
Ideally you would want the pressure sensor as close or plumbed directly to the wastegate its self if possible. Since I have twins it made things a bit more complicated plumbing wise.
My co2 setup should be here tomorrow so I can finish plumbing that up and try and figure out the PID's.
Old Oct 11, 2013 | 08:01 PM
  #129
LILHEMI's Avatar
car looks really really good brotha.
Old Dec 22, 2013 | 05:56 PM
  #130
ion05's Avatar
any updates ? Amazing build by the way hats off to your work.
Old Dec 22, 2013 | 06:07 PM
  #131
Hart_Rod's Avatar
Very clean.
Old Dec 22, 2013 | 07:53 PM
  #132
LS1PUNK's Avatar
Thanx guys.
The car is currently at D3 Performance getting some custom fab work done and will be tuning it when its all done.
Hoping to have another update before the new year.
Old Jan 3, 2014 | 06:35 PM
  #133
1bad03snake's Avatar
When are they going to start tuning it?
Old Jan 7, 2014 | 10:14 PM
  #134
LS1PUNK's Avatar
A few more upgrades/fixes.
I was having issues bleeding all the air out of the system due to the top of the radiator being lower then the vapor block so I had the guys at D3 Performance fab up a surge tank/ higher fill point.
Also had them fab up one of their custom catch cans, replaced all the pushlock plastic vacuum lines with -3 braided lines, and some other small things.
Once everything was done fabrication wise Chris Delgado was working his magic on the dyno but ran into a few issues. First off my alternator took a dump in the middle of a pull so we called it quits till I can get it swapped out.
Second Im getting MAJOR boost creep, I have 6 psi springs in the gates and it hit boost cut (18 psi) at roughly 5300 rpm. As is it made 549/631 with no timing in it.
Going to take care of the alternator next time Im home and figure out what Im gunna do to control boost, either twin 44mm's or 60mm's wastegates should do the trick.
Old Jan 7, 2014 | 11:14 PM
  #135
LILHEMI's Avatar
say **** it and go 60s.
Old Jan 8, 2014 | 09:18 AM
  #136
23_hellfox_23's Avatar
What kind of boost are you planning on running?
Old Jan 8, 2014 | 12:21 PM
  #137
Verz's Avatar
Damn good looking car and build
Old Jan 8, 2014 | 01:54 PM
  #138
LS1PUNK's Avatar
I probably will end up doing 60's that way I dont have any issues with the other motor building boost too soon.
I dont have a specific number just what ever it takes to make the power I want and is controllable.
Thanx.
Old Feb 5, 2014 | 03:16 PM
  #139
PRAY HRD's Avatar
Subscribing......any updates? VERY nice build!!
Twin 44mm WG's will dump a Lot of pressure! Handled my 402/T6-88mm turbo setup from 11-22psi without any creep what so ever to 949rw. (technically had a 44 & a 46)
Currently acquiring parts for a twin build myself so looking forward to seeing progress. My a2a is a twin bottom inlet, 3.5" top outlet and was very excited to seeing your idea for going between the top support & radiator. Current plans are to cut and remake a top radiator support such as most do when standing up the radiator in an F'body (as i did in mine as well). I may have to look into seeing if i could do this first. What diameter is the tube on yours if you please?
Old Feb 11, 2014 | 04:15 PM
  #140
ion05's Avatar
My favorite foxbody build and you have been very helpful with all the questions ive asked. Keep up the great job and updates. I am actually using your build as inspiration for my own build.
