98-2003 Camaro Brakes on a 68 Camaro
What would it take to convert a 68 Camaro w/ 4 wheel drums to a front disc setup using 98-03 brakes? what parts would i need? master cylinder? lines? booster? and from what car?
all you really need is the calipers and rotors ..and some minor machining on the drum spindles and drum hubs ....booster/mc optional....if you have staggered shocks then you will need 2 rear right calipers and back plates...or lefts i forgot
lol ....sorry ....ummmm and thats about it wheel fitting may be a problem depending on your wheels
Originally Posted by HotRod68Camaro
gEtyOPaPiOn - have you done the swap? if so got any pics?
i only plan on doing the fronts. what kind of machining do you mean?
i`ve done the swap but dont know how to post pictures here
....can someone show me how ? thanks....i have 2001 ls1 brakes on the front and 97 on the back ...im also using the 2001 booster and master cylinder and the abs controller
....can someone show me how ? thanks....i have 2001 ls1 brakes on the front and 97 on the back ...im also using the 2001 booster and master cylinder and the abs controller Thread Starter
how much did it cost you guys that have done it?
gEtyOPaPiOn - could you e-mail me pics at MetalBassist16@hotmail.com
....can someone show me how ? thanks....i have 2001 ls1 brakes on the front and 97 on the back ...im also using the 2001 booster and master cylinder and the abs controllerThanks.
this are the results when you on a budget lol....nothing but other cars parts ...cant afford dem baller parts
...but here are some pictures...
...but here are some pictures...I would like to see a picture of how you set up the relutor and sensor for the front brakes.
TIA.
And Use Honda Accord Or Any Other External Honda Pick Up Sensors
