is300 swap
that being said with a rear mount i bet the cheaper lc1 set up would be fine.
baby is perfect. there was about a 15minute period that was very scary when her heart rated dropped and they did an emergency c section. both mother and baby are doing great now.
I was really wondering a couple of things about your rear-mount setup: First, I was wondering if you had any idea on the stats for the hot side of your turbo? I'm guessing it's a T4, but the A/R and exducer diameter of the wheel would be handy...
Secondly, I'm guessing your exhaust setup was a 3" tube, and that you simply kept the 3" tubing up to where the rear turbo was, cut that off and replaced with a turbo? I'm trying to figure a couple things out for a setup I want to do this spring/summer, and I think I want to use either a 2.25" or 2.5" tubing setup to keep exhaust gas velocity high back to the turbo.
Third, did you wrap your exhaust back to the turbo?
And finally, what size tubing did you use on the cold side, was it aluminum, and did you use an intercooler?
Thanks!
Thanks!
i ran 2.5" from the front to the back and no intercooler. i am running e85.
my next steps if i keep working on the car will be a serious fuel system, maybe an intercooler and add boost till something breaks or the turbo runs out. i wouldn't be surprised if this turbo ran out before reaching 700rwhp and my tranny or rear might give out before that.
that being said i dont get too nuts around corners but the car is a blast to hang the tail out for fun
i did get some pics of the rear mount set up. >> http://neufamily.org/images/is570tgallery/index_8.htm
