Driveshaft problems!!!
If you have a local "you pull it" type yard, yokes for non performance applications are pretty cheap. If you're going racing I would buy new.
Depending on the transmission you are using, the yoke may be quite easy to source from a salvage yard because many transmissions used the same yoke or transmission across several models / years.
The car yokes should easily bottom, but must not be driven bottomed. They should drive about 1" from bottomed.
