LTX --> LSX Conversion Sticky
Old Sep 16, 2012 | 06:43 PM
  #101
the_merv's Avatar
Basically your pink wires need 12v..coming from a fused circuit somewhere. I've been getting them to convert over without having to add any extra circuits.
Old Sep 16, 2012 | 10:26 PM
  #102
Slow94Formula's Avatar
Got it figured out. Boy do I feel dumb! Only had to move one wire from C101 to C100... Oh well, now it starts!
Old Sep 16, 2012 | 10:54 PM
  #103
1961ba427's Avatar
Glad you got it figured out!!
Old Sep 17, 2012 | 10:28 AM
  #104
Now I have another small issue. The tach does not work at all. The wire that I pulled from the LS harness to signal the tach under the dash was from C105 G. Apparently not correct. Where should I have taken that from?
Old Sep 17, 2012 | 07:37 PM
  #105
the_merv's Avatar
What was the name of that wire?
Old Sep 17, 2012 | 07:40 PM
  #106
(+ NW9) Tachometer Signal
Old Sep 17, 2012 | 08:05 PM
  #107
the_merv's Avatar
I don't see why it wouldn't work..
Old Sep 17, 2012 | 08:06 PM
  #108
I don't know either. Is there another wire you have in mind that I could try?
Old Sep 17, 2012 | 09:26 PM
  #109
the_merv's Avatar
Is it matched up to the proper one on the car side?
Old Sep 18, 2012 | 09:35 AM
  #110
Almost positive I put it in C230 D which would be the right one, but I'll have to double check I guess.
Old Sep 18, 2012 | 05:39 PM
  #111
ZonJuice's Avatar
why is the ltx rack not usable? i have a 93 camaro that has a old style small block using the lt rack and old style power steering pump with custom lines. im converting to a 5.3L turbo setup. just curious
Old Sep 18, 2012 | 06:25 PM
  #112
93Z2871805's Avatar
Veteran: Air Force
Because of the angle that the steering shaft comes in at. LT1 is almost straight into the rack, LS1 is at about a 45* angle. If you were to try and use yours it'll hit the pan.
Old Sep 19, 2012 | 07:07 AM
  #113
Strokinit383's Avatar
In actuality, the racks are very similar. I had both racks laying side by side for comparison. There cant be more than a 10-15 degree difference between the two. I had a bit of trouble with the LS1 rack initially, so I contemplated throwing the lt1 rack back in. If you are running truck manifolds, as I am, you may be able to squeeze them. But I cant guarantee this. The linkage will be very close to your manifold. The main advantage of the LS1 rack comes from the hard/fixed linkage as opposed to the jointed piece.
Old Sep 19, 2012 | 09:25 AM
  #114
ZonJuice's Avatar
i am running a ls1 shaft that was extended. and will be using foward shorty headers, possibly custom made. but i understand the problem now. i guess i will tackle that when i get to it. thanks for the info guys.
Old Sep 19, 2012 | 01:54 PM
  #115
the_merv's Avatar
I have a picture in my link on the first post of this thread. LS1 Rack & Linkage clears Headers alot better.
Old Sep 26, 2012 | 06:03 PM
  #116
Now I need to figure out why I am not getting fuel on the passenger side. I pulled all of the plugs and the passenger side looks brand new still. Checking over all of my wires and not finding what I did wrong. Anyone have any help to give there? Been looking at this and diagrams for hours. Now what did I do wrong? lol
Edit: disregard... I am retarded once again
Old Oct 23, 2012 | 07:01 AM
  #117
nascarnate326's Avatar
anyone regret this swap?
I'm fairly noobish to LS scene but have the urge to swap. Every time something on my LT1 goes wrong I just think "if I had a ls1". I have wanted a 5.3 for years. Am I crazy?
Old Oct 23, 2012 | 08:22 PM
  #118
93Z2871805's Avatar
Veteran: Air Force
No
That's what made me switch
Am I crazy?
Don't know you well enough to say, lol.
Old Oct 23, 2012 | 10:06 PM
  #119
the_merv's Avatar
Don't hang out with Kenny..
Old Nov 12, 2012 | 11:18 AM
  #120
SupermanZ28's Avatar
Finally about to give up my LT1... Giving me way too many problems and I'm ready to go ls... Is going with a 5.3 worth it or should I wait and try to find a lq for a reasonable price? I know the lq works best with ls3 or 243 heads, but what about the 5.3? Other than intakes, what ls parts are actually interchangeable on the 5.3?
