Major problem with build!!!! A little help please!!!
I recently attempted the "first start" on my L92 engine installed in my V6 camaro. All i got was backfiring. No start. Later i learned that i needed to replace the cam phasor, with the 4X cam gear.(lingenfelter converter box)
after a 3 day war with, harmonic balancer, i finally got it off. then i removed the timing cover and checked the dots out of curiosity to see if they lined up because of the backfiring. they did. Next, i grabbed the ratchet and began to remove the cam phasor bolt. immediatley i noticed the bolt wasn't tight at all. came off with very little effort. from what i can tell, the the gear was turning over but the cam itself wasn't. the dowel on the cam had slipped out and was scarring the back side of the gear. what do i do?
