Can't find pcm
Old Aug 17, 2011 | 02:47 PM
john.starkweather's Avatar
Default Can't find pcm
Just pulled an lq9 out of what I assume is a 2003 escalade. Truck was an insurance car and most of it was burnt. The motor and the majority of the wiring is ok. The car came to me from a body shop and most of the panels have been stripped off. Is the module I have pictured the pcm? I cant find any pcm that looks like that but it does line up with all of the engine wiring. If its not the pcm maybe sombody took it?
Also is that the VIN on the back of the module? If not where can I find the VIN? The doors are gone so I cant get it off the sticker. All of the glass is gone so if it was etched those are gone to. I heard sometimes they are in the glovebox but I have no glovebox. The windshield VIN is burnt. Is it etched into the frame or put on to the motor or transmission anywhere?
Old Aug 17, 2011 | 03:05 PM
rao's Avatar
rao
That is the PCM. Take a look at this http://cgi.ebay.com/ebaymotors/Engin...-/270701105232
The VIN can be pulled from the PCM with the proper software. Otherwise you will have to hunt it down from the body shop, the body itself or the paperwork,
Old Aug 17, 2011 | 03:14 PM
Ok so why is this one so different Im used to the red and blue connectors. Are the pin outs different?
Old Aug 17, 2011 | 03:19 PM
garys 68's Avatar
It's an 07 truck ecu. You'll need the wiring diagram for 07+ vehicles.
Old Aug 17, 2011 | 03:36 PM
Ok thanks for the help. I think I need to locate the VIN first so I know what car it is.
Old Aug 18, 2011 | 05:43 AM
psiconversion's Avatar
LS1Tech Sponsor
Looks like it had a 6 speed automatic transmission as well which would have been an Escalada or Denali. Definitely a 2007 as stated previously.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Aug 18, 2011 | 07:32 AM
Old Geezer's Avatar
Take a look at the vertical surface at the dr rear side of the block, at the trans flange.
If the trans and engine are a matched set, the vin may also be stamped, [laser etched], on the bellhsg flange on the dr side.
Old Aug 18, 2011 | 08:13 AM
Pocket's Avatar
Be careful using wiring from a burnt car. It may look ok, but that doesnt mean the heat hasnt wasted the jacket making it impossible to strip
