bench seat and a t56
Lou Santiago did a Nova on "Muscle Car". With an LS1/T56. I remember he modified the tunnel a bit, and also modified the seat frame to make a pocket. I think he was able to just work the fabric a bit to make it look factory.
Trying to find info about that is like pulling hairs. You have to buy the DVD to get any decent pictures of the car...that ive been able to find anyway.
But if I find it, Ill post it. Might help ya out.
J.
EDIT: Here's a thread with a couple pictures of someone else's car.
http://www.stevesnovasite.com/forums...d.php?t=164498
I found that a Viper T56 has a forward location as compared to the F-Body (or GTO). I move the shifter forward and does clear my Bench seat on my Chevelle.
What has to be converted is the Input shaft and the front case plate. (for the most part).
The best thing to do is figure out where the back of your motor is going to be then measure where you want your shifter. With all the T56 transmissions you can buy an offset shifter that allows you to move the shifter up to 38mm or 56mm in any direction.
Note about using the front access panel location, if you are using a factory trans, ie.. Viper, Camaro, etc... to use the front location you have to disassemble the transmission and cut the shifter rods to make the kit work. With the T56 magnum it is already setup for it and you just need to add the right shifter on top of it without disassembling the trans.
