Mating a SBC/BBC Trans (T10, Muncie, Richmond, TKO) with an LS motor
Old 11-16-2017, 12:35 AM
  #201
ZeroTraction's Avatar
Subscription submit! Love finding these threads that I can use later! Great info guys thank you
Old 11-22-2017, 11:09 AM
  #202
Stampede4ever's Avatar
Does anyone know if you can redrill the bellhousing bolt pattern on the Tremec 3550/TKO trans, like the fords 3550, to GM's Muncie bolt pattern?
Thanks.
Old 12-19-2017, 04:58 PM
  #203
APillow's Avatar
BOOM!!!
Ford / 4th Gen T5 to LS adapter: http://www.hotrodworks.com/product/f...ssion-adapter/
Sorry for the slow movement... A Jeep slowed progress on the Volvo swap where this junk is going.
Old 12-19-2017, 05:22 PM
  #204
Kkern's Avatar
this thread is relevant to my interests
Old 12-20-2017, 10:35 AM
  #205
douglee25's Avatar
Originally Posted by APillow
BOOM!!!
Which honestly is not a good option. The Ford and Chevy T5's aren't rated for much more than ~300 lb ft of torque... that won't last long behind an LS.
Old 12-20-2017, 11:53 AM
  #206
Received 3,146 Likes on 2,453 Posts
Yeah the T5 was a child of the 80's, when engines had a hard time pulling the fuzz off a dandelion...
Old 12-20-2017, 02:04 PM
  #207
APillow's Avatar
I have a used POS Non-WC T5 behind a 5.3 w LS2 cam for years. No problems. But, I do not leave hard in 1st.
Everyone talks trash about the T5, but IDK anyone personally that has broken one aside from regular use/abuse. From kill stories, it seems that 3rd is the weak link.
With the new T56 sychro rebuild kits for the T5 I bet the TQ/HP limit will be raised.
A fellow local gearhead has a TKO500 behind a Caddy 500 Turbo (1000+ TQ) in a Gen III Camaro - daily - and it lives! Not apples to apples, but dont sleep on a T5 base.
Shoot a WC T5 driving a low gear small tire car could live forever... Maybe.
Old 12-20-2017, 09:17 PM
  #208
S10xGN's Avatar
Upgrade the WC T5 to an Astro or G-Force gearset, they're rated over 500 ft-lbs...
Old 12-22-2017, 02:22 PM
  #209
You can go through a few T5s, at the right price, before even getting close to a used T56 or Tremec, that's my plan for now.
Stampede.
Old 12-22-2017, 03:42 PM
  #210
Project GatTagO's Avatar
Received 1,443 Likes on 911 Posts
Michaler Yount uses a T5 behind a LS3 in his Volvo. I think as long as the T5 is not abused and there are some traction problems, a T5 will be fine. The great thing about T5s is that they are light, relatively small, shift great, and are well supported in the aftermarket.
Andrew
Old 01-23-2018, 10:02 AM
  #211
machineica's Avatar
Hello Everyone,
The formula is set i see for using the ls motors with the shorter crank. What about if i already have an engine with the longer crank?
I got tunnel vision while shopping for a LQ motor. Finally finding a LQ4 for $500. When i arrived at the location noticed the truck was a '99.
Pulled it myself and got it home, tore it down noticed the crank seemed to be longer. Which started my search finding out about earlier 6.0s and then this forum and post.
What i have is a 69 camaro with a TKO600 and a quicktime bellhousing. Ditched the SBC for an LS build and now im sweating the details of the conversion.
I tried searching online but didnt find conclusive info if there ever was a silverado 2500 with a 6.0 and a manual trans.
Read through all these posts on this thread and i dont think unless i missed it where anyone had the long crank.
Additional searching online found this site which has some useful info, but for the short crank guys.
https://www.novak-adapt.com/catalog/...en-3-flywheel/
And with some additional details on crank spacing. https://www.novak-adapt.com/knowledge/gm-crank-spacing/
So looking like my options are?
1. Replace the crank?
2. Machine the crank?
3. machine the ls bolt pattern in a BBC flywheel since the crank is in the old style length?
4. Purchase an LS00-28 from the novak adapt place. ( I'm just trying to save money like everyone else here.)
Anyone ran into this yet?
Michael Rock
Old 01-24-2018, 04:32 PM
  #212
Michael,
I don't believe that the 2500 with a 6.0L ever came with a manual transmission.
I know you may not want to hear this, but if you got the engine for only $500, why not sell it? Sure seems better than buying a bunch of expensive parts to cobble together a questionable solution.
Andrew
Old 01-24-2018, 09:58 PM
  #213
CattleAc's Avatar
From earlier in this thread...
For 10 spline you can use a flywheel off an 05 Silverado 1 ton truck (Sachs 1050). It bolts to the crank and is drilled for an old school 11" BBC clutch. For pressure plate and 10 spline disk, just get one for any late 60s/early 70s BBC application. I think transmissions switched to 26 splies around 73, so you can even use this flywheel with a 26 spline clutch. The other advantage is that the flywheel is about 0.400" thicker, so the disk is correctly placed on the trans input shaft and the earlier throwout bearing and clutch fork geometry will be the same as the BBC application. Downside is that flywheels extra thickness comes with extra weight. Oh yeah, and the Sachs 1050 flywheel is about $60, and 11" clutch is only about $120.
Old 01-25-2018, 09:03 AM
  #214
machineica's Avatar
Michael,
Andrew
I don't mind the cost if i get a good result. I will need plenty of clutch engagement (+/- 550 hp)so the sachs clutch might not be able to work for me anyway.
No can do on the sale the engine for 500. Block already refreshed, bored .030 over fitted with some +4 cc forged pistons, Heads Texas speed PRC cnc machined. too late to stop now. i can always buy another crank.
Just was hoping to use it because of the old school geometry with the crank being in the proper place for the bellhousing and trans i already own.
Michael Rock
Old 01-25-2018, 09:06 AM
  #215
machineica's Avatar
Dosent look like any of these earlier mentioned solutions will work for me, I am 26 spline and my crank is already .400 longer due to being an early 6.0 that was teamed with the 4l80.
Michael Rock
Old 01-25-2018, 11:53 AM
  #216
Michael Rock
If your block is ready to go, just get a new later model crank. You can even choose a OEM forged crank, like the LSA crank. Just my opinion....
Andrew
Old 01-25-2018, 12:07 PM
  #217
AnotherWs6's Avatar
I agree. My experience was in the fox body world, but it's relevant. Back then people were blowing T5's up all of the time. I managed to put 140,000 miles on my modified 91 with out a single problem. Clutch started slipping well past the 100,000 mile mark. Was I easy on the car? Sure, often. The rest of the time? Hell no. A young guy in a loud, fast Mustang? Do the math. But I'm not an idiot and it survived with well more than 300lbs of torque for many years. I'm sure it was blown up promptly after selling the car, but it did just fine for me.
BTW, the car never had anything but high perf street tires on it. And 3.55's which lov-lov-loved.
Old 01-25-2018, 01:06 PM
  #218
machineica's Avatar
Andrew
Now were talking. I like where you are going with it.
Old 01-25-2018, 02:17 PM
  #219
vertigosity's Avatar
Alternatively, I think those early truck cranks have the same pattern as the car/late crank, but the offset of an old SBC - so you could get an LS1/2/3/7 flywheel and clutch combo (which has the correct spline pattern for the TKO), and it should in theory have close to the right stack height for the original throwout arm/bearing. It's worth doing some measurements, but for running an old transmission on a budget, that almost seems like the ideal crank to have.
Also, if you're going hydraulic clutch, the shims or lack thereof (at least the Quarter Master slave that I used... IIRC because GatTagO used it?) behind the slave cylinder can take up the slack in either direction.
Old 01-25-2018, 04:34 PM
  #220
garys 68's Avatar
The novak site has a listing for a manual trans 4.8 flywheel for long crank.
Might be worth checking into for a long crank 6.0.
Quick Reply: Mating a SBC/BBC Trans (T10, Muncie, Richmond, TKO) with an LS motor
