Mating a SBC/BBC Trans (T10, Muncie, Richmond, TKO) with an LS motor
#341
In order to use the SBC clutch, you'll need the Sachs flywheel, probably want to index and balance the assembly. In addition, I think it needs to be the 11" clutch for the 168 tooth flywheel.
Just go with Andrews suggestion and the long throwout bearing.
Ok, this is the 3rd time in a couple of days here that I've tried to respond to this. The first times I had pictures of my crank flange, this time I'll post without and see if it goes through. The picture was just to confirm that I have the flush flange.
Basically I wanted to thank both of you guys, cula8r and Gary for responding. I really appreciate your help.
Also, I already have a friction disc and pressure plate that came off of a SBC that only have a few hundred miles on them.
Is it NOT an option to bolt them to a regular LS flywheel?
Neither of you recommended that option, which seems like it would be the cheapest/easiest in my situation. I'm curious of you rationale why I would not go that route?
#342
FWIW, I'm still trying to go manual. I have the zbar, bought the relocating bracket, and have a set of long-tube headers that look like will clear without a problem. But don't want to confuse this great resource/thread by posting that until I can confirm. It'll be a while, just had shoulder surgery, trying to get the rest of parts around so I can be ready to start thrashing out some progress when I'm mobile in a few weeks.
#343
I can tell you 02 vette Z06 exhaust manifolds will clear the z bar and flow as well as most aftermarket headers. Also keep in mind you have 3 stock locations (bellhousing, A body, corvette brackets) on the engine to mount the Z bar and can easily relocate the frame mount depending on engine location.
Excellent guys. This is the rationale I needed. I would not have thought the LS6 and LS7 were different, and if I have to replace part of it in the future I can come back to this and know why I shouldn't pick up my SBC parts that will inevitably still be sitting in a dusty corner and not try to put them on.
The following users liked this post:
nvm (03-10-2022)
#344
I'm currently running this with my TKO600 very satisfied.
https://www.speedwaymotors.com/Tilto...YaAskGEALw_wcB
Hydraulic Throwout bearing options for TKO?
Here's my parts list. I have everything except my mystery throw out bearing
6.0
LS7 clutch and flywheel
Ancient Lakewood Blowproof (sbc style)
GM TKO 500
LS1 Master cylinder
G-body chassis
Hydraulicthrowout bearing??
I'm in the process of removing 406/TKO combo (mech clutch linkage). I'd like to re-use my TKO rather than a t56.
I didnt realize a hydraulic TO bearing would be a challenge on a TKO. Is there anyone aware of a kit that allows the use a modern style hyd TO bearing on a older style transmission?
I don't want to run a slave cylinder because G bodies dont really allow for that for both clearance and bell housing issues
If anyone sees an issue with the parts list above, please let me know. Thanks
***looks like i found it*** posting for others benefit.
If anyone sees conflicting parts in my list please let me know
https://ramclutches.com/product/78131/
6.0
GM TKO 500
LS1 Master cylinder
G-body chassis
**UPDATE**
RAM hydraulic TO DOES NOT CLEAR LS7 CLUTCH
It is clearly NOW stated on RAMs website
Looks like I should have gone with LSFOX suggestion and ran a tilton. Now I have $600 tied up in release bearings, and I get to pull the trans back out of the car.
#345
clarification
I am new to the site, tons of info! Looking for 1 specific piece of info. To use a t10 with the 5.3 , using a sachs 1050, an ls7 pilot, would an an 06 corvette pressure plate and disc bolt to the 1050 and work with the clutch fork throw out bearing
#346
Is the T10 26 or 10 spline input shaft?
QUOTE=heysej;20463344]I am new to the site, tons of info! Looking for 1 specific piece of info. To use a t10 with the 5.3 , using a sachs 1050, an ls7 pilot, would an an 06 corvette pressure plate and disc bolt to the 1050 and work with the clutch fork throw out bearing[/QUOTE]
#347
It is a 26 spline input
