ls1 in a 68 camaro
Old Oct 7, 2011 | 03:04 AM
wayne33's Avatar
Default ls1 in a 68 camaro
Has anyone used solid motor mounts or do i need to run really motor mount?
I have a ls3 pan and SBC motor mounts.. it seems the pan is on the subframe, plus holes are a little off on frame mounts on one side..
thought i would add a pix
Old Oct 7, 2011 | 08:34 AM
tsnow678's Avatar
Sweet ride you have there!!!
I only know of one person on here that is using the Moroso solid mounts. Most people swapping in the LS engines are using the Energy Suspension poly mounts. That is what I used. I ended up flipping my adapters and in turn flipped the mounts. I had to do some slight modifications to make this happen but nothing too overwhelming. I dont believe the LS3 pan will work. The general public are using a few different choices: Moroso LS pan ( I used the deeper of the two and had to modify my subframe), Autokraft pan is popular, Street and Performance modifys the F-Body pan but is ridiculously high and thats about the best out there. The problem the first gens run into is the clearance at the rear of the subframe and clearance at the steering linkage. I have no issues with the steering nor the rear of the subframe but the belly of the pan rested on top of the crossmember. I am using Swaptech adjustable adapters set at the standard position.
Old Oct 7, 2011 | 12:46 PM
wayne33's Avatar
thanks for the info tsnow678.
that the other problem i have the pan is sitting on top the subframe.. It cleared the steering with good space. i flipped the mounts, im going to try to reinstall motor again..
Old Oct 7, 2011 | 01:41 PM
Rocketrod's Avatar
Nice looking ride!!!
I highly doubt you are going to get the LS3 pan to work, but give it a show. A lot of guys are using the Mast Motorsports LS conversion pan for 1st gen. I used that with S&P adpapters plates and my stock motor mounts. I had to grind the bump off the back of the stock mounts and enlarge the holes a little bit, but it fit with no problem. I am also using Stainless Work headers. They may need a slight dimple depending upon the gearbox your running, but I did not want to use ceramic coated headers again as I have never had much luck with the finish holding up to my liking.
Old Oct 7, 2011 | 01:46 PM
bmf5150's Avatar
Get a autocraft pan ,it clears nice!the S&P pan is too expensive plus there is some controversy about the baffling!
Old Oct 7, 2011 | 02:44 PM
wayne33's Avatar
thanks for the responses guys. Im going to try this pan one more time tomorrow. if not i will have to get one of these other pans
Old Oct 7, 2011 | 02:57 PM
MastMotorsports's Avatar
Let me know if you have any questions about our LS Conversion Pan!
Old Oct 7, 2011 | 03:15 PM
95cam86roc's Avatar
Sorry I'm not going to be any help lol. I just came in to My idea of the ultimate Camaro LSx + 1st Gen. Least from a cruiser/car show/toy stand point.
Btw any idea on what color you are going to paint the car?
Old Oct 7, 2011 | 03:55 PM
wayne33's Avatar
im thinking of viper blue..
@ tsnow678 is there anything to be concern with the pan seating on subframe?
Old Oct 7, 2011 | 06:35 PM
LSCustoms's Avatar
some use autokraft... beautiful car
Old Oct 7, 2011 | 06:36 PM
LSCustoms's Avatar
that blue would be sweet!
Old Oct 7, 2011 | 09:39 PM
wayne33's Avatar
thanks
Old Oct 12, 2011 | 02:40 AM
wayne33's Avatar
well i had to switch to energy motor mount. but the good news is the ls is in without cutting cross member . plus i didnt have to buy another pan.. so just for the record the ls3 pan will work.. i have a 1/4 inch between pan and cross member and plenty of space for the steering.
Old Oct 12, 2011 | 03:16 AM
barryp's Avatar
I went with the Holley pan--love that thing. Hooker headers and hooker sbc mount adapters. Works great!!
Old Oct 12, 2011 | 02:55 PM
efs69's Avatar
Wayne33 could you post some pics of the clearance of the pan and frame and the bottom of the car? also what headers are you using?
Thanks
Old Oct 12, 2011 | 04:31 PM
68maroSam's Avatar
I am using Moroso solid mounts on mine. They are bolted to a sbc frame mount and the Moroso sbc mount welded to home made LS plate. That is a very nice looking ride you have there. What color are you going to go when painted?
Old Oct 12, 2011 | 05:39 PM
wayne33's Avatar
Old Oct 12, 2011 | 06:05 PM
Rocketrod's Avatar
... i have a 1/4 inch between pan and cross member and plenty of space for the steering.
I would keep an eye on this as 1/4" isn't much clearance once you start driving and torquing the motor.
Old Oct 12, 2011 | 07:44 PM
Doug G's Avatar
What tranny ? any issues with a TH350 ??
Old Oct 12, 2011 | 08:35 PM
wayne33's Avatar
i blow the racing th350 up with my 406 sbc. now im going with t56.
