Goodbye 4-Banger, Hello LS2 – Miata Build
#201
While I have some down time I decided to clean up the valve covers. I don't plan on using the plastic engine covers and the stock valve covers were nasty and discolored. I coated them and the timing cover with some VHT Wrinkle paint. I think they turned out nice. Here's what they look like ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](http://i974.photobucket.com/albums/ae226/mkline321/Miata%20Pics/P1010152.jpg)
How has that wrinkle finish held up? Did you prime the parts prior to paint?
Tipsy
#203
It's all about the preparation. Clean them really good with a brush and some dish soap to get all the oil off first. Dry and warm them up in the oven for a bit. Make sure you coat them really well with just one coat of the wrinkle paint. Then stick them back in the oven at about 150° for an hour or so.
Oh yea, make sure you open the windows.
#204
I plan to get some drag radials and try again in the spring. I'm hoping to break into the high 10's with some extra grip.
#205
After about six thousand miles, they still look like the day I painted them. I painted my 4 cylinder covers the same way and they still looked good after about 10 years.
Oh yea, make sure you open the windows.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Tipsy
EDIT: VHT has a video on Youtube. In the comments, it's mentioned that primer should be used on bare aluminum. The video also indicates multiple coats are necessary for proper results.
#207
I've done a few this way and always had great results. No primer and just 1 coat. A second coat takes away some of the wrinkle from the finish, IMO. But then again, multiple coats uses more of their product.
#208
Nice build, man. I would love to have something like this. I've got a buddy that shoved a turbo 5.3 in one a few years back. I believe he said it ran a 9.90 before he had to pull the motor and crush the car.
I don't think I would be able to get all the way in the throttle in either car.
#211
However will you manage to do that?
#214
Whats the average Vette weigh...3200, 3300? If so, 800-900 lbs
Maybe I've gotten used to it but it doesn't feel that crazy. I'm sure it's attributed to the smooth power delivery/broad torque curve of the LS motors.
#216
#217
#218
Great build!
