Alternator Bracket Suggestions?
Old Oct 22, 2011 | 04:15 PM
Fryguy302's Avatar
Default Alternator Bracket Suggestions?
I'm putting a junkyard ls1 in a G-body with a small turbo.
We want to only run a stock water-pump and alternator, no other accessories. We also want the alternator mounted high, and on either side of the engine.
Any suggestions for brackets that will do this, either factory or aftermarket?
Thanks for any info.
Old Oct 22, 2011 | 05:27 PM
bczee's Avatar
Suggest you check out the Kwik setup, http://www.kwikperf.com/lsx_alt_ps.html
or
Speedway bracket only kit.. http://www.speedwaymotors.com/LS1-Vo...ket,35274.html
Old Oct 22, 2011 | 06:45 PM
tmcmillan5's Avatar
Here is a neat one. Tony
https://ls1tech.com/forums/new-produ...rnator+bracket
Old Oct 23, 2011 | 07:54 AM
Fryguy302's Avatar
Thanks!! I think that's what I'm looking for.
Old Oct 23, 2011 | 11:04 PM
96gt4.6's Avatar
Originally Posted by tmcmillan5
Worked like a champ for me as well!!!!!
Has seen 6K limiter many a time, no abnormal belt wear or walking. The above mentioned speedway one looks good as well if you want to move it to the driver side head.
Old Oct 23, 2011 | 11:15 PM
the_merv's Avatar
Veteran: Air Force
That kit there looks really nice, wouldnt work for my S10 build(hood clearance)..so I made my own..
Old Oct 23, 2011 | 11:32 PM
96gt4.6's Avatar
Ooo, very nice.
You must have some LOW hood clearance. The Motovative Performance one puts the alt right at the Fcar oil filler neck height as you can see in my pic. Maybe 1/2 to 1in above the fuel rails/tb tops.
I had the Smokinhawk bracket before, and ya it presented hood clearance issues with me as well, notice how high the alt sits:
Here you can see how insanely high it was with that bracket:
Old Oct 23, 2011 | 11:47 PM
the_merv's Avatar
Veteran: Air Force
Yea that wouldnt've worked for me..where mine sits right now I have maybe 3" to the under-hood bracing. The Engine Bay in a S10 isnt that big..
Old Oct 23, 2011 | 11:48 PM
96gt4.6's Avatar
I see, very creative job on the bracket man, looks good!
Old Oct 24, 2011 | 12:06 AM
the_merv's Avatar
Veteran: Air Force
Thanks..just some scrap steel, plasma cutter, and a welder..
Old Jun 6, 2012 | 09:19 PM
dragonkrs's Avatar
nice bracket looking good
Old Jun 7, 2012 | 01:42 AM
the_merv's Avatar
Veteran: Air Force
Thanks.. It's a pretty good fit..been painted since them pics..
Old Jun 7, 2012 | 05:37 AM
Old Kid's Avatar
On my LS-1 I made a simple alt only mount using a 3/8 aluminum plate (made a plywood template first). Milled 3/8 from the back of the factory bracket to make up for the thickness of the plate. Bolted to head and block using original bolts. Had to trim alt cooling air hood slightly to clear coil. Contact me if you need pics or info.
Attached Thumbnails Alternator Bracket Suggestions?-rambler-162.jpg   Alternator Bracket Suggestions?-rambler-163.jpg
Old Jun 7, 2012 | 07:26 AM
cruisin'73's Avatar
Default Cheap Options
Hey Fry Guy, Here is a couple pic of the alternator mounting I came up with:
I am using a truck crank pulley and waterpump, so I needed 3/4" forward offset for the F-body alt mount.
I got this idea from GC99TA's build:
https://ls1tech.com/forums/conversio...sx-swap-3.html
Hope this helps a bit. Good luck!
Old Jun 7, 2012 | 10:10 PM
the_merv's Avatar
Veteran: Air Force
Some people have put the tensioner in the stock alternator location.. Anyone do that?
Old Jun 8, 2012 | 05:17 AM
Pop N Wood's Avatar
I mounted a Denso alternator off the side of the head.
Old Apr 6, 2013 | 08:11 AM
Fryguy302's Avatar
I ended up going with the Dirty Dingo bracket. Car is done now.
