Camaro Front Accessories parts list (99-02)
For those wanting/needing to use Camaro Style front accessories because of hood clearance issues, or to make room for some turbos, etc. I have put together a list of part numbers, etc. Will maybe even through a few picts in to show what the part looks like next to the number, so that it is easier to figure out, if you are not used to doing this type of stuff...
Alternator:
rear bracket PN 12556915 (verified)
front bracket PN 12563327 (verified)
alternator bolts (need 2) PN 11516366
alternator bolt (need 1) PN 11516360
alternator PN
![](http://i149.photobucket.com/albums/s71/gtsdesigns/IMG_20111111_204115.jpg)
small is for the rear, bigger is the front (obviously...lol), the idler pulley goes in the top left hole of the bigger bracket in the pic
![](http://i149.photobucket.com/albums/s71/gtsdesigns/IMG_20111111_175809.jpg)
the alternator all cleaned up and painted
Idler:
Belt Idler Pulley (1) PN 12564401
bolt (if it doesn't come with it and i think it needs a spacer or something?) PN 11516356
![](http://i149.photobucket.com/albums/s71/gtsdesigns/IMG_20111111_154206.jpg)
cleaned and painted
Balancer:
Balancer PN 12553118
Washer PN 12600525
Bolt PN 12557840
ARP balancer bolt and washer 234-2503 Summit Racing
Alternator:
alternator PN
Idler:
cleaned and painted
Balancer:
Washer PN 12600525
Bolt PN 12557840
Tensioner:
Tensioner (shows that it comes with pulley and bracket) PN 12560344
Bolts (need 2) PN 11515768
Water :
Pump PN 89018053
Pulley PN 12552059
Bolts (apparently you need 6) PN 12551926
![](http://i149.photobucket.com/albums/s71/gtsdesigns/IMG_20111026_112422.jpg)
has tensioner installed on it
Water :
Pump PN 89018053
Pulley PN 12552059
also, i havent seen a thread like this, and had to do a ton of research and looking stuff up, to get the list, I have seen one for corvette, but for those, like me who dont like that style and need the room up top, i made this thread
if you are using an iron truck block, you will need to drill and tap the hole for the front alternator bracket and alternator to bolt onto the block (the aluminum block should have this already)...
I used the following, which came with the right bit and tap (for stock bolts)...
![](http://i149.photobucket.com/albums/s71/gtsdesigns/IMG_20111111_154256.jpg)
![](http://i149.photobucket.com/albums/s71/gtsdesigns/IMG_20111111_154244.jpg)
the top hole is the one that was done
![](http://i149.photobucket.com/albums/s71/gtsdesigns/IMG_20111111_154228.jpg)
![](http://i149.photobucket.com/albums/s71/gtsdesigns/IMG_20111111_154234.jpg)
and the alt mocked up before cleaning and painting it
![](http://i149.photobucket.com/albums/s71/gtsdesigns/IMG_20111111_134700.jpg)
![](http://i149.photobucket.com/albums/s71/gtsdesigns/IMG_20111111_134709.jpg)
![](http://i149.photobucket.com/albums/s71/gtsdesigns/IMG_20111111_134649.jpg)
the rear bracket hole is already there and works perfect, with the alt
but some have either used the bmr relocation brackets
http://www.bmrsuspension.com/?page=p...d=56&catid=149
with an electric water pump and that can be expensive...
then some have just taken it off and ran a shorter belt, etc.
https://ls1tech.com/forums/conversio...lt-number.html
https://ls1tech.com/forums/15604243-post64.html
this front brace, goes in between the pulley and pump...
http://parts.nalleygmc.com/showAssem...ssembly=380420
number 14 in the diagram... hard to get a pict with everything together...
yeh... cant get a picture of it, prob without taking the pulley off, which i will once its back on the engine, its between the pump and pulley, I will take a pic when I change the pulley, cause this one came with it chipped...
![](http://i149.photobucket.com/albums/s71/gtsdesigns/IMG_20111124_175716.jpg)
I added a pict of the main bracket in my previous post
