LS Swap Questions
Is there a list of year / make / model of GM trucks with the LS motor?
Also, some of these motors for sale are listed as 6.0 LS (for example) but the intake cover had "Vortec" written on it. I was under the impression "Vortec" was a slightly different animal...or is this just labeling the type of intake system. Sorry for the noob questions...this swap deal is all new to me. Thanks for your time!
Hope this helps.
Vortec is a trademarked name for a line of piston engines for General Motors trucks. So, Yes.. Just a Label ! It has been used in SBC / GEN I and GEN III/IV and the BBC engine family.
66LS, you need to state what your Goal is, usage and Budget. In general the Vortec / Trunk engines will be the cheaper way to go. But you can't go wrong with any of these GEN III/IV engines !!..
In general, accessoire and intake are interchangeable. Yes there are two Head/intake port configuration and a few other minor area, but nothing that has not been worked around already.
suggest you research the FAQ area and the A-Body swaps that are already documented in the build threads. (see my link in sig for mine). The try asking your questions specific to small areas, you well get better respones and answers.
Good Luck.. keep us posted.
BC
You will find a lot of information on this site. Welcome.
Jon
PSI
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
it was 2004 and the VANs used drive by cable later then the trucks and suv's, maybe even into 2005.
Keep the 2wd vans in mind if you are on a budget.
I would just make sure you get the flexplate that comes on the engine you find. It will have the spacer included. As far as which flexplate you will need I am unsure of that but if you do a search the information will be readily available. If you do not find what you are looking for, PM me and I have a few people on here I can ask. I would opt for as new of an engine as you can afford. Preferably an LY6 (6.0). They have the L92 heads on them which flow great. No porting needed and you get 335cfm at .600 lift. The valves are a little heavy but with some Patriot Gold springs you will be fine. That all depends on which cam you choose though. I used an LS3 intake off of a 2010 Camaro complete with injectors, rails, intake and bolts for $225. It was like new as it was a take off with less than 30 miles on it.
Jon
PSI
Ebay Store
Sam
