LS6/T-56 swap: '71 El Camino
Yes, engine and transmission from an '05 CTS-V. Couldn't say how far set back/forward it is. Seems like I had to cut more of the transmission tunnel than the chevelle swaps I've seen here.
Right now I'm trying to figure out the master cylinder situation. Do I need to replace the slave cylinder too, and if not, can I connect the new master to the slave without having to separate the engine and transmission.
Have to take the engine back out. Ordered a new clutch master & slave cylinder. Trying to work out fuel system next. It looks like I can get a stock '95 Caprice sending unit and put it in my stock fuel tank with the Racetronix fuel pump. Thoughts?
Installed new throwout bearing, and clutch master, replaced brake booster. The engine and trans are still separated. I want to clean up the fire-wall and redo all wiring, but I have yet to formulate a plan. Does anyone make stock items like headlights, wiper motor, heater, etc for A-body but with modern connections? I wou...Oh no, pictures! And how would oil be leaking into my bell housing?
installed steering gearbox, wasn't sure it would fight, but it does; all right.! Next issue is a new rag joint. will I be able to remove the flange on the steering shaft or will I have to cut it? I think I've the fuel system planned out too.
Thinking about using a fuel tank from 99-02 camaro. Sound good? Easy enough?http://www.google.com/imgres?q=%2799...ayZzWDQ&zoom=1
Nooooooooo!!!!! *sigh*.....maybe, someday I will correct my abhorent level of procrastination. Right now, it cost me again. There was a great deal on a fuel tank and pump from a camaro on ebay motors, but no more. On the bright side I have occasion to use this emoticon:
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Have you checked out the tanks inc setup and just use your existing tank?
http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm
started to put suspension back together. I took some metal to the scrap yard and I think my old steering arms were in there, so that's now holding up progress. Ordering replacements from OPGI. Also, does it look like I'm missing anything between the brake booster and master cylinder? and on the transmission front I found this thread :
http://www.performancetrucks.net/for...nstall-485277/
I already have that style of offset lever; so can I just buy a new short throw shifter and fab up some adapter plate? Thanks.
Make sure to check the depth of the socket in the M/C to make sure that the booster pushrod will just make contact at static position. It looks like your booster pushrod is adjustable to compensate for the various M/C depths. Otherwise it looks correct, sometimes you will find a rubber boot in the booster. It really wont matter if it is there.
