Ls3-tci 6x e39 528 (pic heavy!!)
Old 11-02-2012, 02:18 AM
  #121
mikesanto70's Avatar
Originally Posted by Jesus Freak
Here's a couple pics of them polished.
Also, I'm getting ready to wire up my neutral safety and have a question. One, what switch do you guys use? A regular GM switch won't work, I tried.
And two, the start wire from my ignition is a switched ground wire, how do I go about wiring it?
Thanks
How the heck did you get those to shine like that and have that brushed like finish!!!! Looks Killer!!!
Old 11-02-2012, 08:46 AM
  #122
Jesus Freak's Avatar
Trade secret.. Lol jk
I use a 60grit sanding belt on a pulley that attaches to a variable speed grinder.
Old 11-02-2012, 07:07 PM
  #123
1CAMWNDR's Avatar
It may not matter, but if my welding skills were that badass, I'd get back under the car and fully weld those transmission mount brackets in. Is the 6x 4L80E heavier than the BMW tranny?
Old 11-02-2012, 08:46 PM
  #124
Weld it to the body?
The 6x is heavier than the stock trans, but the engine feels lighter than stock. So it may balance out. Didn't get before or after weights
Old 11-08-2012, 10:14 PM
  #125
Teaser....
I'll get better pics with my DSLR later.
Old 11-12-2012, 10:02 PM
  #126
Old 11-13-2012, 08:05 PM
  #127
ACHTUNG's Avatar
Nice headers!
Old 11-14-2012, 12:10 PM
  #128
Pure84GTT's Avatar
headers turned out great
Old 11-14-2012, 12:16 PM
  #129
Thanks guys.
Old 11-14-2012, 09:38 PM
  #130
Hmm... Tempting....
Old 11-24-2012, 10:29 AM
  #131
Finally finished up some other projects and got some time to work on the car today.
This is only tacked on, I used my 110 TIG welder, spent 20 minutes preheating it, just to get a decent tack.
Old 11-24-2012, 06:57 PM
  #132
Sub-par's Avatar
Beautiful car man. How's the production plan for the headers coming?
Old 11-24-2012, 07:19 PM
  #133
Thanks.
No production plan yet. All the places I've emailed either aren't interested or want a minimum order of 10+ sets. So right now they'll stay hand made.
I just finished up a second set yesterday and dropped them off to be coated black.
Old 01-22-2013, 12:48 PM
  #134
So it's been below freezing here for the last week or so and I've noticed my fans are on constantly, they never shut off. The first day I noticed it, it warmed up to 40* later in the day and they didn't turn on until the set temp, 210*. But as of lately they're on and do t shut off until I turn the car off. I can read engine temp just fine through the OBD port.
Any ideas? Bad temp sensor?
Old 02-15-2013, 10:11 AM
  #135
Fan issue was just a relay.
Was having a fluid and filter change done as the 500 mile service recommended by TCI, ordered filter and fluid directly from them... They sent me the wrong filter, I emailed customer service and he said I had the correct filter part number, I sent them pics of the obviously incorrect filter, then he contradicted himself and said that was the wrong part number. They're not even sure what goes in their own transmission. Lol
I'm kinda curious if that's what happened last time and caused the trans to go out the first time
Old 02-15-2013, 11:23 AM
  #136
Jay Gadsby's Avatar
Beautiful build! My favorite BMW chassis for sure.
Old 02-17-2013, 09:54 AM
  #137
mcdave71's Avatar
Mentioned before, the lines running into the bottom of the cooler will trap air in it. Feeding lines in and out the top or even on it side will allow all air to bleed out.
Old 02-17-2013, 11:11 AM
  #138
I bled the cooler lines tho. Cracked the return side while the car was running until fluid came out.
Doesn't matter now anyway, the new cooler is top fed and has 2.5 time the cooling capacity. Lol
Old 05-01-2013, 09:00 AM
  #139
Well there goes trans #2... I'm very frustrated and disappointed with TCI thus far
Old 07-27-2013, 11:48 AM
  #140
This is tempting... http://www.turbobygarrett.com/turbob...t/turbocharger (GTX3071R)
TT, ITB...
Focus... Stereo first...
Quick Reply: Ls3-tci 6x e39 528 (pic heavy!!)
