Chevelle 4.8 Turbo
Old 07-04-2012, 12:21 PM
  #261
AlterEgo's Avatar
Originally Posted by 68BBChevelle
You can put it on a stand and get it running that way. Or put it in your car and just use the manifolds you work out all you n/a bugs. Then bolt on your headers and turbo kit. Im with 99vette start N/A then go turbo. Think you would have less headaches that way.
Ok, 68BB, I hear what you and 99vette are saying about starting out n/a, my concern is spending money on parts that I will not need for my turbo build and then having to sell them at a loss... I plan on using a TBSS or ls2 intake with a 92mm TB, with ls2 injectors and rail on my turbo setup. With your own personal experience and knowledge, do you think that will happen as far as headers and tuning for the 2 different setups?? (headers and tuning at a minimun, I know there will be more differences between the 2 setups..)
Old 07-04-2012, 02:06 PM
  #262
68BBChevelle's Avatar
You can run your tbss or ls2 and 92 with your N/a setup. Only thing would change out would be your injectors,tune and headers for the turbo. There could be couple other things im not aware of but im sure 99vette can point you in the right direction.
Old 07-04-2012, 08:28 PM
  #263
99VetteFRC's Avatar
I bolted the engine in the car and used the stock manifolds, just welded vbands to them, then made temporary pipes to hook right into the exhaust that was on the car for the BBC. So it didn't cost me a dime extra to make the car run n/a. I have the HPT and took out the vats and egr and stuff I didn't need and the engine ran excellent on the stock tune. Remember that engine pushes around a 4000lb full size truck so the stock tune works very well. I used a second set of manifolds to make the turbo manifolds but I already had them, didn't need to buy. Now that they are off the car I will save them for another ls swap down the road. I just made sure some things I bought {i.e. fuel system} was good enough to run the turbo setup. I only wanted to buy that stuff once. It was easier to get the engine in the car and running and work out the bugs and make sure the engine was right before going FI.
Old 07-05-2012, 06:31 PM
  #264
AlterEgo's Avatar
hmmm.. you just gave me an idea... You were right by the way, I suppose I will get it all running first and then make my mods from there.... (you did see my point though when you said, "I only wanted to buy that stuff once..") I suppose Ill give those 706 heads a run for a while.. Ill just get a cam and intake since mine is all busted up, get it running and go from there..
Old 07-05-2012, 07:32 PM
  #265
Daz
Daz's Avatar
I'm using 241's(for now), 2004 Z06 cam(405hp Z06), 799 springs !
Old 07-05-2012, 10:27 PM
  #266
99VetteFRC's Avatar
My engine was all stock. I just put the boost on the stock engine!!!
Old 07-09-2012, 08:44 PM
  #267
99VetteFRC's Avatar
Got the intercooler and piping kit today.... Gonna start install later this week.
Old 07-16-2012, 04:31 AM
  #268
99VetteFRC's Avatar
Intercooler is in!!! Now to get it tuned.
Old 07-16-2012, 07:19 AM
  #269
kainedogg's Avatar
Keep the pics coming brother. Your progress is motivation for the masses!!
Old 07-16-2012, 11:31 AM
  #270
99VetteFRC's Avatar
Here are some pics I took with intercooler installed. Took my LS6 Valve springs out of the other engine, wanna put them in next week. Then Wide Bands and tuning.
3" intercooler behind the grill
Everything installed!!!
Each turbo has a 2.5" outlet that goes through a BOV pipe and then into a 2.5" routing. Then they go to a 3" merge pipe that I made and into the 3" intercooler and then 3" pipe into a 90* to 4" to the MAF and TB.
The merge pipe.
I ran the 3" pipe under the core support as to not cut the car up. I did have to put a small notch on each side of the bumper for the pipes to clear but I figured the bumper is easy to replace if I ever want to.
Old 07-16-2012, 12:27 PM
  #271
kainedogg's Avatar
Wait so you have a single inlet intercooler? I need better pics of the plumbing since I have not yet committed to an intercooler and don't care to reinvent the wheel. How much hp does it support? Are you using the stock chevelle radiator and electric fans?
Old 07-16-2012, 04:41 PM
  #272
99VetteFRC's Avatar
I don't know how much HP it will support. I didn't think of that, I ordered one that would fit in the car. Yes it is a 3" single inlet and outlet from CXRacing on ebay. I just mad a 3" Y-pipe to hook turbos to. I will try to get some better pics tonight.
Old 07-16-2012, 07:14 PM
  #273
kainedogg's Avatar
Thanks bro, and info on the radiator and fans...please.
Old 07-16-2012, 07:16 PM
  #274
99VetteFRC's Avatar
Old 07-16-2012, 07:25 PM
  #275
kainedogg's Avatar
Much obliged bro.
Old 07-17-2012, 04:37 AM
  #276
99VetteFRC's Avatar
Originally Posted by kainedogg
Much obliged bro.
No problem
Old 07-17-2012, 06:49 AM
  #277
kainedogg's Avatar
Check out the motor going in the C10 in my sig bro.
Old 07-17-2012, 11:30 AM
  #278
99VetteFRC's Avatar
UMMM.... I wonder where you got that idea!!!
Old 07-17-2012, 12:07 PM
  #279
kainedogg's Avatar
Lol, what are friends for.
Old 07-17-2012, 07:40 PM
  #280
99VetteFRC's Avatar
HEHE... glad to have a friend online!!!
Quick Reply: Chevelle 4.8 Turbo
