EZwire universal chassis harness??
Aces good info you have there. Maybe check out the KwikWire product. They use the GXL wire that the more expensive kits use. This kit falls right in the middle at $280. The main reason I'm going Kwikwire vs Ez is because they are a real American Co and the harness is made right at their shop in WI and not overseas somewhere.
I just found out they're all made in China.....
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
That would explain the immensely lower prices. No thanks!!!!!
Sticking with another American Made product when it comes to electrical.
I've seen China's quality control.....
I never even thought to look up where EZ-wire is made.....
I just found out they're all made in China.....![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Awesome! If you unwrap that harness can you make a note of the length of the steering column plug from the fuse box? I think that is the limiting factor in where the fusebox can mount....
