5.3 truck & 5.7 A/C compressor mounting questions
I have a 5.3L engine & I switched the truck accessories out for the f-body accessories on front on the engine. I have the truck compressor but it will stick out too far with truck A/C bracket. What I need to know is are both compressors the same on a 5.3/5.7? Can I use a f body compressor mounting bracket & the truck compressor or will I have to get the compressor from the f-body also?
I'm working through a similar issue. I have an LS6 going in a truck. I can't use the vette compressor/bracket and have to use a truck comp/bracket. Totally different mounting set ups. What year is your truck compressor? I'm looking for an '02 because it has a high pressure switch built in the compressor and the 04' vette compressor I have doesn't have the switch built in. Let me know if you are interested in a swap.
Thread I posted related to my issue:
http://www.ls1truck.com/forums/lsx-t...sue-truck.html
