5.3 90 fox hatch t56 need advice
hey guys, new here to gm stuff and new to ls1tech. im over on theturboforums all the time (stangboy86), thats where i got the inspiration for this project, and my buddy is footing the bill. we will post a build thread as we go along. so far we have a pretty much stock 90 mustang gt with 109k on the clock. car is white with black interior. we picked up an lm7 5.3 out of a truck. so far we plan on going carb'd for its simplicity and standard transmission. it will be na for now and possibly boosted in the future. got a couple questions for the more experienced guys here:
truck manifolds work?
t56? or should be go tko trans? if t56 which one? camaro, gto, or vette?
clutch cable or hydraulic?
summit or jegs intake and msd box.. any complaints?
local guy will customize driveshaft.
i will build exhaust and trans crossmember if needed.
the idea is a nice fast chevy powered street car.
i'll post pics later on. thanks in advance for the help guys. i will keep a detailed build thread to hopefully help others figure this stuff out
ok project going a different direction, just picked up an 02 ls1 and mildly built t56. plan is to keep the efi instead of going carb. any advice on the best way to make the efi and hydraulic clutch work would be appreciated. not sure if megasquirt is the way to go... seen someone else morf a camaro harness into a fox, dash cluster and all. and advantages to doing it this way?
just looking for someone to help point me in the right direction. thanks
pete
pete
Why not just keep the stock efi setup, have the ecm flashed and pick up a harness from psiconversions or someone similar? Is the holley efi setup beneficial for a stock or relatively stock motor? Seems like a big chunk of change for the application.
What do you want for gauges? Stock fox, aftermarket, or camaro cluster? From what I understand psi conversion can make your harness easily adapt to a camaro cluster, that's the route I'm going, the ford gauges are fugley.
LS1Tech Sponsor
As boostnut stated, our standalone harness would work the engine and transmission independently of the Mustang Harness. We provide gage output as well. Give us a call or PM us to discuss specifics. Thanks.
Jon
PSI
Jon
PSI
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic84531_2.gif)
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
found the link
https://ls1tech.com/forums/conversio...ybar-pics.html
wow guys these are the answers i am looking for. i think my buddys main concern is being able have working gauges and a working speedometer especially. he is not opposed to using a camaro cluster. def gotta get with psiconversion... thanks a ton guys and keep the advice coming. i will post pics in the next week or two once i get whats left of the car here.. my buddy pulled the motor, trans, interior, and nose off it. gonna start with beefing the torque boxes, welding subframe connectors, and k member swap. aje k member and mounts seem to be the way to go
LS1Tech Co-Founder
Holley HP EFI is $1500 on Summit Racing. Compared to getting a custom harness, stock pcm, tuning software you can easily get to over $1200... Plus Holley HP will self-tune which I think is pretty cool.
i was thinking its no prob to use the ford sending units for oil press and temp in the gm motor.. using adapters if necessary. by "tail shaft piece" you mean the adapter that goes into the tranny? anybody making adapters for this?
we already have the stock pcm. i thought if worse came to worse i could do megasquirt pretty cheap?
LS1Tech Sponsor
Unless you are building a big turbo/blower motor, or making insane horsepower, why wouldnt you stick with the factory electronics? Aftermarket systems DO have their place, however, when it comes to anything BUT an insane combination, it is more than capable, easier to tune and extremely reliable. Just my 2 cents.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
Jon
PSI
Jon
PSI
forgot to mention, may be going back to plan a.. 5.3 truck engine except def want to keep her efi... deal on the lsi looks like it may fall through
any thoughts on a good cam.. efi stock lm7 engine, something that is proven
and maybe good if we go boosted later on
we picked up a t56 out of a (02 i think) camaro, got an ls7 flywheel, ls7 clutch, the pedal assembly, shifter, hydrolic master slave and line also out of the camaro. gotta figure out how to get it all working in the mustang.
also ordered the aje k member, ls1 mounts, t56 crossmember, torque box kits, and subframe connectors. car is stripped getting the engine bay smoothed now. cant wait to get some stuff done!
