game-over's 69 lsx 1/1/13 new pics (UPDATE) pg.10
Old 02-08-2012, 12:38 PM
  #61
game-over's Avatar
Originally Posted by tsnow678
Darn skippy its Christmas in PA!!! Heads look awesome! Did you get any flow numbers? Are those Patriot springs? How bout some shots of the ports and combustion chambers.
ill take some pics tonight.. that was just a few quick shots as soon as i got them..
Originally Posted by bmf5150
nice!
thanks man
Old 02-08-2012, 12:40 PM
  #62
game-over's Avatar
Mill heads to __62cc______
Ferrea 2.04/4.900/8mm Intake valve
Ferrea 1.575/4.915/8mm exhaust valve
TFS LS-1 1.220 Titanium spring retainer
1.300" DUAL 140# 400# .650" 1.070" COIL BIND
Stef's .505" 1.3" spring cup
LS-1 Valve seals (brown)
Fully assembled stage 2 cnc ported LS-6 Heads
CUSTOM GRIND LS-1 HYDRAULIC ROLLER 226-230 -113
7.400 Pushrods
LS1 Multi Layer Steel Gasket Set heads WITHOUT notch
Crank Bolt-LSI
LS-2 TIMING CHAIN
GM LS RETROFIT TRUNION KIT
R&R upgraded rocker trunions in stock rocker rarms
Old 02-08-2012, 10:51 PM
  #63
game-over's Avatar
Old 02-08-2012, 10:53 PM
  #64
game-over's Avatar
Old 02-08-2012, 10:54 PM
  #65
game-over's Avatar
oh no missing my shoes
Old 02-09-2012, 09:47 PM
  #66
game-over's Avatar
my cam specs... got today
BRP parts....
Old 02-10-2012, 03:45 AM
  #67
tsnow678's Avatar
Man those heads look awesome! According to the flow numbers, the intake is almost flowing as good as an LS3 head! How you like the looks of the BRP kit? It seems to be well made. Cant wait to see how it all installs. I am hoping its smooth sailing for ya. Did you figure out what you are going to do for brakes? Whatever you do, dont throw away the brake drum hubs from the front. Some kits available, usually the large hat style rotors, use them with disc spindles. I shed mine years ago and regret not having them now.
Old 02-12-2012, 10:53 AM
  #68
game-over's Avatar
yeah man.. im loving the heads ... i dont know what im looking at but they look awesome...lol
BRP stuff looks legit to..... i hope it all goes in as smoothly as they say it will... we'll see.. im about to pull the motor out so i can sell it.. then i'll start taking pics of the engine build.....
i havent figured out which way i want to go yet with brakes......
so many options....lol... ill def ask more questions when i can get closer to a choice..
other than the engine, tranny.. ill probally keep almost everything... we'll see tho...
Old 02-12-2012, 10:56 AM
  #69
game-over's Avatar
well... sold my 71 wheels i wasnt feeling the wheels on my car... i loved the tires and the sizes i used... but the rims had to go... i sold them to a local guy and got a descent amount for them .... that same day, i found a set of (2) 15x7 and (2) 15x8 gm rally wheels with tires on CL .... i picked them up today.... not feeling the tires size but i can change that later...
tony hope you like them
Old 02-12-2012, 10:58 AM
  #70
game-over's Avatar
and i want the white walls/ letteres out..
does anyone know of a good "sticky" tire that has white walls/letters...
i'm striking out...
Old 02-25-2012, 11:59 AM
  #71
game-over's Avatar
assemb motor tom morning
old motor is comin gout tonight or next weekend... looking for a wrench session tonight
Old 02-27-2012, 10:32 AM
  #72
game-over's Avatar
block is torn down...
arp rod bolts installed...
getting another new air compres. because this one took a **** on me.
ordered a DSE gas tank last night from cabin creek... cant wait to see it...
Old 02-27-2012, 12:24 PM
  #73
tsnow678's Avatar
I love some rallye wheels! I get the itch to change mine out from time to time but always come back to leaving the "stock appearing" look. I notice you have the rounded off Corvette trim rings on the back and the stepped Camaro rings on the front. They sell the smae style of trim ring for the 7's that will match the rears if interested. I bought a set of 4 stainless rings for like $50 on Ebay.
Good to see your starting on the new engine. Are you going to go all the way through it or just change the rod bolts? I swapped my rod bolts out without any issues but have heard about people running into problems distorting the big end since the ARP's are so much longer. I turn my 6.0 on up without nay issues and I did not resize my rods.
I have been lucky on air compressors. I have a Speed-Aire that I purchased 17 years ago and its still running strong. I change the compressor oil out periodically with Mobil 1 and so far so good. If it crapped out today I would be happy to buy another one just like it. Of course the next one will be a two stage. the increased volume and pressure would not only make it more useful but should last longer as well since it will not work as hard or run as continuous. I think the single stage I have is maxed out 140 psi and the two stage tops off at 175-185 psi. I have a large nitrogen tank I use if I need pressures above 140. You ought to hear my 900ft/lb impact with 225psi behind it!!!
Keep the pics coming!!! Best of luck to you on the swap.
Old 02-27-2012, 09:26 PM
  #74
game-over's Avatar
i didnt even notive the rings.. but thats good to know...thanks
we'll see what happens with the rod bolts.. went in smoothly..lol
i was so so mad sat the compressor.. lol would have made my life easier oast night...
thats nice you had a compressor that long...
Old 02-27-2012, 09:27 PM
  #75
game-over's Avatar
out with the old
damn you compressor ... i will win... lol
torn down block
brp mounts
not sure why my pictures are so big
Old 02-27-2012, 09:30 PM
  #76
game-over's Avatar
im at the cross roads... where did everyone mount there pcm... i would like to know if you had a mondified one or stock length
Old 02-27-2012, 09:33 PM
  #77
GOrilla's Avatar
Doing a 1st gen LSx swap myself. Awesome project man. Keep at it.
Old 02-28-2012, 03:48 AM
  #78
tsnow678's Avatar
I used a longer wiring harness and a modified Ironworks bracket. My PCM is mounted vertical behind the battery.
Old 02-28-2012, 01:06 PM
  #79
game-over's Avatar
THANKS MAN
IM LOOKING FOR PICS bur cNT find any
Old 02-28-2012, 01:26 PM
  #80
69 Ghost's Avatar
For your brakes keep your drum spindles and convert to LS brakes you will be money ahead. I have a set of rear LT1 brakes if interested.
Quick Reply: game-over's 69 lsx 1/1/13 new pics (UPDATE) pg.10
