adjustable alternator bracket
Old Feb 23, 2012 | 03:48 PM
Gray86hatch's Avatar
Less weight and lower in the car.
I can use it with any engine.
Gets rid of the stock style hoses.
Pull the timing cover without touching the water.
Tim
Old Feb 23, 2012 | 04:37 PM
cyipher's Avatar
Thank you i see what you did now. How did you plumb your steam vent? tap the moroso fitting?
Old Feb 23, 2012 | 04:54 PM
-4 line to rad tank below the upper hose
Tim
Old Feb 23, 2012 | 05:43 PM
2baditsnotachev's Avatar
Very nice setup gray86. That bmr doesn't say it will work on a 5.3 block though. Now I planned on going from the upper hose into a proform sbc standard electric pump mounted remotely then from the the two outlets into the top holes of moroso plates, out the bottom holes into the moroso remote t stat housing, then back to the lower radiator. Sound like a working setup? I don't care to run all an lines as im on a tight budget, I just want the space for my turbo.
Old Feb 23, 2012 | 07:24 PM
You have to drill out a boss in the block for it to bolt on. Lots of guys do it not a bid deal.
Tim
Old Feb 25, 2012 | 10:07 PM
well that's just something I came up with quick. Think it will be rigid enough to keep the belt on?
Old Mar 2, 2012 | 11:29 PM
pdlightning's Avatar
Originally Posted by Gray86hatch
Bmr makes one.
Have a remote pump on mine.
Uses f-body balancer
Tim
What about the y-body balancer? Does BMR or anyone else make the a/c or alternator mounts and tensioners when you remove the water pump?
There are a lot of people with LS motors that need low mount accessory drives, but have the closer y body balancers.
