Aftermarket gagues for '68 LeMans
my car was a 4 wheel drum non power brake car.
i used this kit.
http://www.speedwaymotors.com/1964-1...ombo,8299.html
this is the master and booster i used. smaller than stock booster and works great.
it comes with a adjustable screw type proportioning valve i mounted mine under the car in front of the rear control arms. easier to mount and less stuff under the hood. the master has the orifices removed so it works fine with 4 wheel disc. if you want to run rear drums residual valves would have to be added.
i used this kit.
i used this kit.
i used this kit.
