Fuel system fittings?
Thanks
For the reg/filter, I used the cutoff section from that originally mated to the fuel rail and cut it to length. One end (male)mates to the reg/filter (female) the other end was straight hard line that I attached the above mentioned adapter to. Did the same thing at the fuel rail, just attached the hard line adapter right to the fuel rail leaving me with an AN fitting.
LOL OH WELL I GUESS IM NOW 28 DOLLARS IN THE HOLE LOL THAT MAKES IT LIKE 9235723895723897329.43 FOR OTHER MONEY BAD SPENT SO FAR LOL For the reg/filter, I used the cutoff section from that originally mated to the fuel rail and cut it to length. One end (male)mates to the reg/filter (female) the other end was straight hard line that I attached the above mentioned adapter to. Did the same thing at the fuel rail, just attached the hard line adapter right to the fuel rail leaving me with an AN fitting.
67ls1CamaroProject: Thanks for the tips on the hard tube adapters. They're going to work out perfectly. Those pics are worth at least 1000 words each.
