Smoothed Truck Intakes
Old Sep 30, 2013 | 07:49 PM
  #161
omc8's Avatar
Originally Posted by 87lsttop
So its not like an epoxy filler that you mix and spread on and then sand smooth. Something like bondo?
What exactly are you trying to do ? Are you wanting to bond or just finishing work to prep and paint ? Or are you talking major surgery ?
Old Sep 30, 2013 | 08:19 PM
  #162
ACHTUNG's Avatar
I have an intake from a LQ9 sitting in my shop collecting dust. Anybody want to take it off my hands to try and smooth it? Let me know.
Old Sep 30, 2013 | 09:25 PM
  #163
87lsttop's Avatar
Just to amooth it out since bondo is not very good.
Old Oct 2, 2013 | 06:00 AM
  #164
Chad pickens's Avatar
why not bondo for cosmetic repairs ?
Old Oct 2, 2013 | 03:56 PM
  #165
BOXCHEV's Avatar
Bondo and reinforced bondo(filler with short strand fiberglass hairs in it) does not always stick to good with plastic. Usually you would need to grind plastic with around 24 grit or so to "key" it into the plastic for it to bite.
#1 I would use a plastic filler rod and plastic weld more material onto the intake. Grind down with 80grit and work your way up with the grit to get a smooth finish so it's all 100% nylon plastic. If needed, clean and degrease the intake good, use a adhesion promoter and try a high build primer.
You can use a old spoon or something and a torch, heat up the spoon with the torch and use it as a plastic welder to melt the plastic into the intake.
#2 could try the 2 part epoxy from urethane supply as a bondo alternative, get their plastic cleaner and plastic prep too. After sanding that you can do a real light skim coat of bondo. I believe on my epoxy tubes it says it also bonds with fiberglass and body fillers. I'll have to check to be sure. So the epoxy sticks to the plastic, and the body filler sticks to the epoxy.
I say no fiberglass and filler on the plastic, especially the intake because not only does it not bond well, I don't think it would survive the constant heat cycles. So option #1 would be my choice. Keep it all plastic.
Old Oct 3, 2013 | 04:22 PM
  #166
Im using sheetmetal for a new top.I dont think welding is gonna work.
Old Oct 3, 2013 | 08:56 PM
  #167
Leadfoot85's Avatar
does anybody know what paint color this is?
Old Oct 4, 2013 | 03:08 AM
  #168
BOXCHEV's Avatar
Ahh, did not know that.
Well I dont see that working to well either. I don't picture any kind of glue working for you then to attach sheetmetal for a top. Even if you went with a mechanical bond.
Old Oct 4, 2013 | 07:10 PM
  #169
Old Oct 4, 2013 | 11:32 PM
  #170
slowbu's Avatar
Wow the truck intakes don't look so bad with some work done to um.. Anybody got any links or a thread where they ported the gen3 intakes I've seen what gets done on the tbss an gen4 styles is it the same style of porting for the early ones 2?
Old Oct 5, 2013 | 07:52 AM
  #171
That red intake is what inspired me!!!!
Old Oct 8, 2013 | 08:22 PM
  #172
omc8's Avatar
Chad , what concerns me about your lid is leaks from the rivets ! Have you tested it for leaks ?
Old Oct 8, 2013 | 08:30 PM
  #173
BOXCHEV's Avatar
That was my concern when I mentioned that I didn't think a mechanical bond would work. Even if there were some RTV or something there to try and seal it up. If it passed a leak test I would be concerned how long it would last after that.
Old Oct 11, 2013 | 01:46 PM
  #174
I think the filler and the powder coating will seal it
[IMG][/IMG]
Old Oct 11, 2013 | 02:09 PM
  #175
T/ALT1's Avatar
I didn't think you couldn't powder coat over bondo?
Old Oct 11, 2013 | 02:33 PM
  #176
Fast86z's Avatar
If not a thick coat of paint should do it. Looks great man!!
Old Oct 11, 2013 | 02:49 PM
  #177
cbrodine's Avatar
Yes... a BADASS color!
Old Oct 12, 2013 | 01:58 PM
  #178
Hey thanks
Old Oct 12, 2013 | 10:07 PM
  #179
Flipper_1938's Avatar
I'm curious how well the intake will seal to the head with just one bolt on most of the runners.....
Old Oct 13, 2013 | 09:43 AM
  #180
a little bit of sealer will seal it even without the bolts so one per runner should be fine for naturally aspirated
