EBay Radiators
Old Mar 25, 2012 | 07:40 PM
Stu Cool's Avatar
Originally Posted by S10xGN
Looks exactly like the Jeg's rad I got for $50 more.
It sure does, but I bet you got a couple JEGS stickers with yours
Pat
Old Mar 25, 2012 | 08:34 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
This radiator looks like it would work really well for me, love to find it a little cheap I should probably check on Jegs again... Has the inlet/outlets on the passenger side.
http://www.ebay.com/itm/390000471730...=p5197.c0.m619
Old Mar 26, 2012 | 12:15 AM
Stu Cool's Avatar
Here is a 28 x 19 from CFR, they also have a 26 x 19
http://www.ebay.com/itm/ULTRA-COOL-2...ht_3975wt_1094
Pat
Old Mar 26, 2012 | 10:23 AM
LS1Tech Co-Founder
Hey Pat, thanks for the link, just bookmarked it!
I'd like to hear how yours works out.
Old Mar 27, 2012 | 10:52 AM
RenoReno2's Avatar
Take a look at griffin, they're making radiators for ls swap direct bolt ins. I got mine off amazon for alot less than I could find elsewhere. This was for a 88 monte though, not sure about your application but might be able to finagle something of the same dimension to fit.
Old Mar 27, 2012 | 11:13 AM
LS1Tech Co-Founder
Hmmm Amazon, I'll check that out too.
Old Apr 3, 2012 | 11:40 AM
Stu Cool's Avatar
My new radiator, shroud and mounting bracket from CFR via Ebay have arrived. Will be working on installation today.
Pat
Old Apr 3, 2012 | 11:42 AM
LS1Tech Co-Founder
Nice. Do you have to add a fitting for the crossover?
Old Apr 3, 2012 | 12:12 PM
Stu Cool's Avatar
If you mean the steam line from the heads, I have mine plumbed to the top of my water pump so I don't need it on the radiator.
Pat
Old Apr 3, 2012 | 12:23 PM
bczee's Avatar
Pat.. looking good.. hopefully this will give you the room to put that intake setup you want to do on..
BC
Old Apr 3, 2012 | 12:51 PM
Pop N Wood's Avatar
I'll bet you could get a drain plug welded onto that radiator for a low price.
Old Apr 4, 2012 | 11:49 AM
  #32
Stu Cool's Avatar
Yup, I am picking up a bung and petcock today ($15) and my friends at the college welding shop are going to TIG it in place for me.
Pat
Old Apr 13, 2012 | 12:42 PM
  #33
Stu Cool's Avatar
Making progress, here is a little teaser:
Radiator shroud and fan set up. I got a bung and petcock from the local radiator shop and a friend TIGged it for me in his college welding class. Also pictured is the top piece I made from 18 gauge sheet metal:
Here is the radiator and top piece being fitted, from the front:
And from the back:
I will be putting the top piece in primer and drilling some holes to anchor it next. I already found hoses that I think will work and I will show those later too.
Pat
Old Apr 13, 2012 | 01:06 PM
  #34
bczee's Avatar
Pat
Nice job on the Fab work on the top / support piece !.. is that going to be painted the Red or chromed out ?
Maybe paint as the same color as the Coil/fuel rail covers ?
BC
Old Apr 13, 2012 | 01:25 PM
  #35
LS1Tech Co-Founder
Are you running F-Body water pump?
Old Apr 13, 2012 | 01:44 PM
  #36
dell's Avatar
I bought a three core off Ebay for $150 a couple of years back. It keeps the motor in my Cutlass Cool. Unless I'm sitting in traffic the fan never comes on and I can't recall the gauge ever reaching 200F..
Old Apr 13, 2012 | 01:46 PM
  #37
bczee's Avatar
From what I recall, it should be a Vette setup..
Old Apr 13, 2012 | 05:09 PM
  #38
Stu Cool's Avatar
It's an F Body motor from a 2000 Trans Am. The top piece will be finished in matching red. I have a number of things I want to repaint, front bumper and one of my mirrors, so I will try to do them all at once.
Old Apr 23, 2012 | 05:29 PM
  #39
Stu Cool's Avatar
OK, The install is complete, except to finish painting. The main reason for doing this was to set up a cold air intake. My original plan was to go over the top of the radiator and put a filter in front of it. But I finally decided I did not have as much room as I thought I had and the filter and tubing would have blocked some air flow in front of the rad. So seeing the Spectre air box on another build sent me in a new direction.
And once inside the fender I routed the duct down to the air scoop at the front of the car below the bumper.
Here's a view from behind
I drove it about 170 miles on a 93 degree day Saturday, before I had the flexible duct installed, and it seemed to cool as well as the old radiator did. Now I am looking forward to see how much of an improvement the CAI makes. my tuner says the ECM will see the cool air and not back timing out like it was doing before. I tell you taking a hole saw to my 60 year old classic car was a little scary!
Pat
Old Apr 23, 2012 | 09:11 PM
  #40
S10xGN's Avatar
Pat,
I'm pretty sure you won't drive that car in the rain intentionally, but if you do get stuck in it, be wary of sucking enough water to possibly hydraulic the engine with that intake so close to the ground...
