rockauto tank??
Old Mar 30, 2012 | 11:56 PM
weircc's Avatar
Default rockauto tank??
im building a 2nd gen camaro ls 6 speed and im wondering has anyone used the tank from rock auto, it has the pump in the tank if im reading right it says its ready to go for an ls swap. thought i would ask before i dropped some coin. thanks
Old Mar 31, 2012 | 07:05 AM
nobreaks254's Avatar
whats the part number?
Old Mar 31, 2012 | 07:36 AM
chuckd71's Avatar
I'm guessing this is the spectra efi tank. It's what I have and it came from rock auto. There is a thread about that tank here somewhere; I think there is a newer version that works better.
Old Mar 31, 2012 | 07:41 AM
weircc's Avatar
i tried posting the part number but they are out of stock right now
Old Mar 31, 2012 | 07:42 AM
weircc's Avatar
and yes i believe it is same tank i read the post it was mostly ppl bashing about what they had heard was wanting some info from ppl who have one thanks
Old Mar 31, 2012 | 08:02 AM
chuckd71's Avatar
I've had no real issue with mine so far but I only have 500 miles or so on it. The filler neck angle was not steep enough and the old factory cap did not fit well (nor did any aftermarket one I could find) so gas would always slosh out but with a little time and $15 or so I fixed that. If I had it to do over again I'd probably just baffle an old tank and use a tanksinc setup.
Old Mar 31, 2012 | 08:17 AM
weircc's Avatar
thanks ill check in to that option as well
Old Apr 7, 2012 | 06:50 PM
weircc's Avatar
can someone tell me the difference between these tanks which one would i need????
w/ Evaporation Emissions Control
w/o Evaporation Emmissions Control
Old Apr 8, 2012 | 12:01 AM
Rick Speed's Avatar
Ok what am I missing. How are you finding the EFI tank on rock auto because I only find the stock replacement tanks
Old Apr 8, 2012 | 12:26 AM
weircc's Avatar
if you look under 70 camaro they have them i have a 71 but its same tank.
they dont show them under 71. in your sig looks like you have 79 T/A which has deeper tank or is deeper on 1 side i seen a write up on nastyz28 to modify that tank pretty easy ill find it right quick
Old Apr 8, 2012 | 12:32 AM
weircc's Avatar
here ya go
http://www.nastyz28.com/forum/showthread.php?t=228464
Old Apr 8, 2012 | 08:51 AM
Rick Speed's Avatar
Oh ok thanks. I thought maybe I was blind and missing something.
