22" wheels make a big difference
I suggested maybe it was the massive 22" wheels that look awesome by the way. Or maybe even the mild cam that may not take advantage of the excellent flow characteristics of the L92's until much higher in the rpm range. I told him the road tune was cool, but lets put in on the dyno and see what it makes, and slap some 17's on it for good measure.
I bought a Miata with some TSW 16 with 205/45 tires. It rode like a dump truck. I always thought it was because of the Koni coilovers. The 16s were going bald so I swapped to stock wheels and tires. The car felt quicker and the ride got WAY nicer.
Food for thought.
Andrew
You also have a higher stall in your car.
Also what is his Tranny shifting at ?
Of course the 22s are going to mess with the handling and responsiveness. Also, has he compared compression ratios with your car's? I suspect he may have a lazier CR (or DCR) than he thinks. I thought my **** was up there, and couldn't figure out why it wasn't so snappy. Surprise! I found out it was actually lower than stock. Anyways, that could be part of it. I would also revisit the head and cam selection if he was expecting more. While rectangle port heads have very nice flow numbers, on a 4" bore I've heard they shroud the **** out of the intake valve. LS3s have a 4.065 bore stock, so they are less shrouded in that motor. Also, back to compression ratio, having a stock compression motor with a lopey cam will actually cost you. Aside from having stock SCR to begin with, releasing some cylinder pressure due to excess overlap will weaken power under the curve and will make the motor not feel as strong on the butt-dyno, or as responsive. Find out the DCR of his motor if you can. I'm no expert, as a matter of fact I have a lot to learn, but he may have made some of the same mistakes in his setup as I have in mine.
A total lose-lose scenario as far as performance.
If you every go to a museum of science and industry most have a display where you roll wheels down and incline. Take equal sized and weight wheels and the one with more weight concentrated out near the edge take massively longer to get to the end of the ramp.
Bigger rims will make you slower.
Will also depend on what kinda wheels, design etc. Full almost solid face wheel will weight more then spoked wheel. What kind of rims are they?
If you are going got speed, I wouldn't put rims on the car.
Checkout this car without rim.
http://youtu.be/YmleR-lZsQ8
http://youtu.be/wDGMGELQDqM
With rims
http://youtu.be/-paDnOj8kV8
Skip to 48 sec mark lol
http://www.youtube.com/watch?v=wrjCT...eature=related
Anyone who owns a car with 22-inch rims NEEDS that car to be slow - otherwise it could outrun their
