4L60E Questions
Old May 1, 2012 | 02:36 PM
72Cutlass's Avatar
Default 4L60E Questions
Hello,
I finally have the funds saved up to buy my LS motor and start my swap, my question is I already have a late 90's (around 97-98) 4L60E that was recently rebuilt before I pulled it out of the totaled car it was in. The place I am getting my motor from is willing to sell me a complete pull out (motor, trans, access., wiring, etc) for $1400 from a low mileage 2005 truck or everything minus the trans for $700. That is a fair amount of money to me at least and my question is how much different is the 97/98 4L60E and the 2005 4L60E? Would my trans talk to the 2005 computer or would I be better off just spending the extra money?
Thanks for any information,
Michael
Old May 1, 2012 | 02:48 PM
psiconversion's Avatar
LS1Tech Sponsor
The transmission will work with your 20o5 electronics.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old May 1, 2012 | 03:35 PM
bczee's Avatar
Ask what the trans came out of ?
Old May 1, 2012 | 08:11 PM
flame's Avatar
The electronics 95+ are the same but you will need the spacer (LS cranks are .400" shorter than SBC) and flexplate with proper torque converter bolt pattern to use an older trans with the LS motor
Old May 2, 2012 | 07:56 AM
LS1Tech Sponsor
I made the assumption that the trans was out of a 98 Camaro/Trans Am. I appologize, will clarify (agree with Flame), if the trans is from an LS vehicle it will work. If it is from 95 or newer it will work as well since it has a PWM TCC function albeit it will need a spacer between the flexplate and converter.
Jon
PSI
__________________
Ebay Store
Old May 2, 2012 | 09:04 AM
bczee's Avatar
That is why I asked the question on what it came out of.. could even have been a 97, LT1 F-Body, (or ?) which would require the Spacer/flexplate, Well you know the routine of using different miss matched years and models.
BC
Old May 5, 2012 | 10:40 AM
72Cutlass's Avatar
Yeah it's from an Lt-1, what's different between and ls trans and Lt trans? is it the bellhousing or the input shaft?
Old May 5, 2012 | 11:05 AM
flame's Avatar
The newer trans have a removable bellhousing and the input shaft and converter are different. My LT1 trans has been behind my LS1 for a few years now. I used the flexplate and spacer from advanced adaptors #712500A.
Old May 6, 2012 | 06:58 AM
Old Geezer's Avatar
My vote: Get the complete takeout. Sell the other trans.
The 05 trans has some improved components in it. [And, you won't be chasing spacers, flex plates, bolts, etc, etc.]
Old May 6, 2012 | 08:57 PM
flame's Avatar
Depends if his current trans has been upgraded. If it is stock then I vote for the complete take out. Rebuilt with good parts then its up to you!
