Which 4L80e Trans?
Earlier versions have both up front like all the other rwd gm trans.
Easy to tell by looking. The cooler lines connections are either next to each other vertically or split front and back.
4l80's all the same for lq,ls,lsx blocks?
Old version, not sure when it changed, is old gen 1 6 bolt pattern. 10 & 2 o clock
Newer ones are LSx. But you can run them as is either way or get the drill out.
2 o clock bolt is missing and they put a top center bolt in instead. It can be a MF to get to. I'd swear they did it so they could put a stud there and hang stuff of it. I think the inline 6 had the top center bolt also. Can't remember what old chevy I saw it on before.
The one missing bolt in the LSx pattern won't matter.
You can make the late model fit by making a custom fitting or buying one.
MightyMouse has a post on the one he made.
