Rebuilding Dad's Panoz; LS1 swap
Old 05-14-2013 | 06:36 PM
  #181
Project GatTagO's Avatar
Originally Posted by Cobra4B
Tapp says all radiators are pressure tested to 32 psi with rubber hoses and slip fit connections. The hoses won't burst, but it's the slip fit that would be the weak point. That said, they do all their testing with slip fits and hose clamps.
Regardless, a little more research shows I have no need for a 30 psi cap and the increased boiling point. A 30 psi cap gives me a 290 boiling point for pure water. I back off at 240 since this is all amateur self-pay no sponsors stuff. Usually the cars will stay in the 210-215 range unless it's a 100+ day and you're on someone's bumper for an extended period.
A 20 psi cap is more than sufficient (260 degree boiling point) for my use. It really doesn't matter if I leave the 30 psi cap in place if I'm going to be backing off at 235-240 degrees anyway. I checked my Corvette and it has an 18 psi cap standard.
Look into the Gates heat shrink hose clamps. They are superior to any worm clamp. Only downside is that you can't reuse them. You may also want to run a 4 corner steam vent, if you haven't done that already.
Andrew
Old 05-14-2013 | 10:15 PM
  #182
Red89GTA's Avatar
Interesting info on the cooling water flow. I guess if you have something that works, don't mess with it.
Old 05-15-2013 | 12:58 AM
  #183
Cobra4B's Avatar
Originally Posted by -TheBandit-
I see the wiring benefit, but you've added unsprung weight and the alternator will be rotating a lot slower that it would on the engine. You'll have slower pinion rotation in all but 1:1 gear (transmission) and the pulley itself is much smaller in diameter than a typical crank pulley. I don't think it will charge very effectively, but I could be wrong. Definitely unique.
A few pounds of alternator is negligible when you have the entire mass of a Ford 9" and 31 spline axles as unsprung weight to begin with. As far as charging ability, we'll see, there is some unknown here, but the car will be at RPM all the time vs. a drag car or a street car that needs charging at lower rpms.
Those are bad ***. I wonder how well they'll hold up over time. Did you print them on an inkjet or laser?
Just hand wrote in ink. They're all covered with wire loom now. Just put them there for reference since most of the wire is the same color.
Originally Posted by ctd450
Very cool build BTW.
Thanks.
Andrew
I saw the heat shrink clamps, but I like things to be serviceable. I'm going to use OEM clamps I have from all my spare Corvette stuff along with a 20 psi cap. The OEM Corvette surge tank cap is 18psi and works well. I'm running the older style four port steam port already. I use the standard one with front ports in my LS6 in my Corvette and have never had issues.
Old 05-15-2013 | 09:39 PM
  #184
Cobra4B's Avatar
Serpentine belt ended up @ 41". According to another Panoz owner with a LS1, this is plenty of belt wrap and works fine. If it doesn't work I can always install a separate idler.
Catch can and radiator overflow mounted. Catch can has feed lines from each valve cover using OEM PCV system ports and one from the rear of the valley cover. Can also has a return line to a -6 AN fitting added to the passenger side of the pan toward the front. No need to drain the can and no issues with oil dripping down on the side-pipe. Got the MAP sensor hooked up as well; uses a barb on the passenger side of the manifold and a tube connecting the two.
Old 05-16-2013 | 09:56 AM
  #185
D_Eclipse9916's Avatar
Brian, (its dj fitzpatrick) are you worried about not running any vacuum on the catch can? Trying to figure out a solution for my setup and worried about no vacuum on it..
Old 05-16-2013 | 11:14 AM
  #186
Cobra4B's Avatar
Racecar doesn't need vacuum on the can. When the engine produces excess pressure it's vented w/o making a mess. Street cars need vacuum because they spend a lot of time at low RPM and idle so they need vacuum to suck crank vapors out and create a flow through the system. On my Corvette I run dual cans in the factory PCV and fresh air feed lines but they're not vented, they hook up to the TB and intake manifold.
Old 05-16-2013 | 12:25 PM
  #187
Andy1's Avatar
It's your overly cautious poster again That belt wrap looks pretty minimal to me. You might keep an eye on it; make note of any fine rubber particles around the belt areas after you run it. Though you may or may not hear it slipping, the particles are usually a sign of slippage.
Andy1
Old 05-16-2013 | 12:39 PM
  #188
ctd450's Avatar
Any info on that tensioner?
Old 05-16-2013 | 12:48 PM
  #189
Cobra4B's Avatar
Andy1
I'm the same way... always doing failure analysis on everything. I plan on watching it closely when the car is on the dyno. You are correct that rubber dust will tell the tale.
Katech manual tensioner. I picked this one up used so it's the older design. I have one on my Corvette as well.
Old 05-16-2013 | 11:37 PM
  #190
Cobra4B's Avatar
Old 05-19-2013 | 08:14 PM
  #191
Cobra4B's Avatar
Radiator overflow hose done, upper radiator hose figured out, and lower almost done pending a tube splice to use half of the OEM Corvette lower.
Hardcore dipstick fabrication. Chrome handle adds a few horses.
Clutch and brake masters bled.
Clutch works. Quartermaster hydraulic throw-out bearing seems to be doing it's job perfectly. Set the pedal stop just past where I can turn the driveshaft by hand.
Old 05-20-2013 | 09:23 AM
  #192
Vexzer's Avatar
Originally Posted by 54inches
Did you get a ramp score?
lol! Cool about the RTI. learned something today. Guess we'll molly the leaves before we go out from now on.
Old 05-20-2013 | 10:57 AM
  #193
Thanks, that makes total sense!
Old 05-22-2013 | 10:11 PM
  #194
Cobra4B's Avatar
Side pipes finish welding done by Mike Balf Racecars. Really nice work... too bad most of it will be covered with header wrap.
Old 05-24-2013 | 08:37 PM
  #195
Cobra4B's Avatar
Pro 5.0 shifter, custom shifter handle, and Hurst ****... Feels awesome. Far superior to the remote shifter.
Coolant hose splice worked perfectly for the lower. Adapted half an OEM C5 hose.
Old 05-25-2013 | 10:37 AM
  #196
TheLS1Lover's Avatar
I very rarely venture out of the F.I. section, but today I'm very glad that I did. Very clean build, and just amazing attention to detail, keep it up sir!
Old 05-25-2013 | 11:20 AM
  #197
vazfx16's Avatar
Very nice. Great job!
Old 05-26-2013 | 12:19 AM
  #198
Cobra4B's Avatar
Thanks for the compliments. Got the side pipes wrapped and installed, filled her with fluids and will fire it up tomorrow. Had a seeping dipstick and one of the heater core ports I tapped and plugged was weeping. Fixed both of those. Got home from seeing Fast 6 tonight (great movie if you like the franchise) and the garage floor was 100% dry.
Old 05-26-2013 | 01:30 AM
  #199
Turnin20s's Avatar
Looks badass man
Old 05-26-2013 | 08:03 PM
  #200
Cobra4B's Avatar
She's ALIVE!!!
Quick Reply: Rebuilding Dad's Panoz; LS1 swap
