Need help wiring trouble
Old Jun 27, 2012 | 10:19 PM
tb8125's Avatar
Default Need help wiring trouble
Guys I have a lq4 with ls1 (1998) intake and harness.... I am using the guage cluster and dash from the same car ... This is all in a 1981 trans am.... I had the car running and moving ... I was backing it out of the garage and it dies hasn't started since been trying to track down the issue since it died..... I think I have a short some where but cant find it.... It only shorts when the key is on .... With the key off 12.6 vdc with the key on volts drop to 1.5 volts...
I am at my wits end with this car... If anyone can help I would be forever greatful... I am willing to pay anyone thats local and can fix my issue
Odenton Maryland
Old Jun 28, 2012 | 07:23 AM
psiconversion's Avatar
LS1Tech Sponsor
Did you modify the harness?
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Jun 28, 2012 | 10:13 AM
Emdmechanic's Avatar
Where are you taking this voltage reading at?
Old Jun 28, 2012 | 11:45 AM
tb8125's Avatar
Harness was reworked by lt1wiring.net
I have a main junction where I have the starter, alt, and ign power, and fuel pump feed and fan power....This is where I was taking power readings
Old Jun 28, 2012 | 11:59 AM
Chrome_Rust's Avatar
check all your grounds. then double check them. Also make sure you have a good solid ground from the engine to the chassis and from the battery to the engine.
Old Jul 6, 2012 | 08:13 AM
tb8125's Avatar
You were right it was just a bad battery ground.... It got a lil corrosion on its.. I put some nooxs on the ends and the cars good to go
Old Jul 6, 2012 | 04:41 PM
2JZFC's Avatar
Glad to see you got it going.
Old Jul 7, 2012 | 12:04 PM
Glad to help!
