Borg Warner S480 Turbo L33 5.3 1991 Mustang Notch build update 3/27
#345
Nope. Honestly I am not overly concerned about it. The pipes are roughly the same length, diameter and number of bends. Might be interesting though. Maybe I will weld in a couple bungs to give it a try later. For right now I am just concentrating on getting it in shape to race. I just ordered my 35 spline axles, cclip eliminators, rear diff cover and install kit last night from Midwest Chassis, a sponsor here. Awesome price!
#348
My main experience with twinscoll systems was with 4 cylinder cars. In those the main thing was to try to make equal runners with similar number of bends. I know it is not scientific in any way but you hear both gates open at the same time. I need to take them both back off and remove a spring. Hitting 16.5 psi on a 14.7 spring.
#349
#350
Congrats, sounds great!
Get a shrouded 2 speed ford taurus fan. You'll never need another.
http://www.ebay.com/itm/Ford-taurus-3-8-sable-electric-hot-rod-2-radiator-cooling-fan-jeep-project-s10-/111205918449?pt=Motors_Car_Truck_Parts_Accessories&hash=item19e463a6f1&vxp=mtr
#351
@lilhemi, oh I plan on it eventually, but want to sneak up on it. I also have a manul controller.
As for the Taurus fan, it may be a tad thick for my application at 4" thick. Would have to measure. I did some testing though and it seems my downpipe/muffler is a tad to close to my metallic lower radiator hose. Think that is contributing to the heat build up when stationary.
#352
Really doubt much heat will be transferred through the metal coolant pipe. I ran my exhaust under the entire length of the radiator. It actually touches the bottom of the radiator... no problem.
#353
Huh, and I thought I had figured the problem, lol. The pipe coming out of the radiator, leading to the engine is actually about 10* hotter than the one leading into the radiator. Right at the base of the radiator is cool, but 4 inches out where it is nearly touching the exhaust it is quite hot. I really though that would be the issue. So you think it is more airflow than the metal tubing being right on the downpipe?
#354
I trimmed the fan down quite a bit. Used them on 4 builds now. They really are pretty badass for the money. May have to angle the top of the Rad forward a bit for clearance. This was before I glassed the top in but I managed to trim quite a bit.
#358
So I about have the rear axle done and was trying to make a spacer to go in between the axle flange and the c-clip eliminators. But the 1/16" steel laughed at my hole saw. I do not have the old rear drum backing plates as I did not have rear drums, this axle had disc brakes. Not sure what I will do at this point. I had hoped to have this finished this weekend. Guess I will have to break out the plasma cutter and hope I can get a nice clean cut. I suppose I will cut inside the circle and grind it out or something.
