Borg Warner S480 Turbo L33 5.3 1991 Mustang Notch build update 3/27
#83
#92
I can tell you already with this AJE K member they will work fine. There will be a bend coming right off the collector, but it is a very slight bend...probably less than 45* and they are facing forward. I am not 100% that I will use them yet, I still want to test fit some of the other manifolds I have, but they look like they would work well. I would snap some pics, but it is hard to see down where the manifolds sit with my phone camera. I will do my best though.
#93
this is a pic of my driver side with a c6 manifold. i wanted to keep my alternator in the stock position but i have since moved it for return line purposes. keep that in mind when building your hot side lol. i didnt.
![Name: DSC00564.jpg
Size: 99.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/676928d1501791986-borg-warner-s480-turbo-l33-5-3-1991-mustang-notch-build-update-3-27-dsc00564.jpg)
#98
I like it. It is not as fast as my mig, but it is more precise to me and for stainless. Or sensitive welds it is nice to be able to control the heat input and build up. It is just a cheap model Lotos that does not have AC for welding aluminum, but it works! I am still learning, but I enjoy it.
#100
Little more progress. Should clear the AC compressor, if not I can always redo it later. But it looks to have decent clearence to everything except the kmember. It only has about 1/2" there....it might end up tapping it if the engine moves too much with poly bushings in the solid mounts.
![Name: IMG_20130127_181712.jpg
Size: 673.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/676936d1501791986-borg-warner-s480-turbo-l33-5-3-1991-mustang-notch-build-update-3-27-img_20130127_181712.jpg)
![Name: IMG_20130127_190518.jpg
Size: 701.9 KB](https://ls1tech.com/forums/attachments/conversions-swaps/676937d1501791986-borg-warner-s480-turbo-l33-5-3-1991-mustang-notch-build-update-3-27-img_20130127_190518.jpg)
