vss issue.. no mph with scan tool
I checked the ecu right at Pin 21 on the red connector ( PPL/WHT ) VSS Input and it has continuity from the VSS plug itself, so why in the world would the ECU not read any MPH? I can understand my gauges not showing mph since I haven't calibrated my gauges yet with the VSS output wire but I don't understand why the ECU doesn't read the MPH since the VSS input wires are connected properly in the harness with the proper gear ratio and tire size flashed in.
Any suggestions? I need to get the MPH working next and then see if it fixes the no shift issue, But regardless, if it doesn't fix the shift issue I still need to get the MPH readout working so the ECU knows when the car is moving.
Thanks!
You can also do a quick check by reading the resistance in the two vss wires at the ecu.
Jon
PSI
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
