LM4 T56 Powered 2001 Miata Frankenstein
Please correct me if I'm wrong, but I thought the CTS-V shifter sits much further back than the F-body. I ran into a couple CTS-V dropouts when I was shopping for my swap and the consensus was that the parts to convert it to F-body made it not worth while. The GTO T56 only required a $30 part to install an F-body shifter.
Check my build parts list for a good list of parts and part numbers.
74modified is exactly right and there will be around $50 and some scrap steel invested in the shifter assembly. The CTS-V is a much better unit than the f-body T56 and actually came from a IRS car so with a little imagination it will fit into the Miata. 74modified also helped a lot with his images
It does not have a huge effect on the car. I am just referring to the driveshaft setup and the fact that the CTS-V T56 does not use a slip yoke type driveshaft actually works for the miata since it is IRS which is what the flex coupler driveshaft type was designed for
I am looking at something like the line in the link.
Has anybody tried this from the fuel tank to engine bay?
should I use 3/8 hard line?
http://shop.advanceautoparts.com/web...%2F8+fuel+line
Im going to be doing a LSx swap to my miata petty soon, i have a LQ4 with ls6 heads and manifold with a tsp tsunami cam. I just got the car about a months ago. Good luck with yours and thanks for the info on this build thread!!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
keep me posted on your build.
we are doing a LQ4 in my friend's Legacy GT
http://i1159.photobucket.com/albums/...8142012239.jpg
You can bend it by putting it in boiling water for ~10 min. A heat gun works but can overheat. As for installing fittings you can buy repair kits.
And here is a thread (post 19 or so) for a DIY fitting press. The real tools ar very expensive.http://m.modernhemi.com/forums/showthread.php?t=1085884
#32
It is becoming common for the factories to use the nylon. One downside is bending and splicing. I am using this piece from a Buick. Nylon on both ends. I am using a return on my fuel rail.
I'll give it a shot.
#35
I used steel braided fuel line from the tank to the filter and return. Also for the feed up to the engine. I'd be a little worried about using nylon under the car without some serious heat/abrasion resistant covering. Especially now after seeing how much heat is generated underneath the car. I also wrapped the braided line with heat tape where it runs near the exhaust and engine.
#37
Did you buy the wiring kit or did it yourself? Do you have the schematics? Could use something to double check my work from. I am planning to run the fuel line through a rubber hose to cover it and protect.
#38
I modified the gto harness myself. I'll dig up my wiring diagrams when i get home and snap a picture of them.
It's nice that you don't have to use anything at all from the Mazda engine harness.
#39
That's great. We have the 99-00 wiring book which from what I saw is mostly the same as the 01+. We are going to use the truck harness that came with the motor. I plan to start trimming off all the unnecessary connections (Auto trans, etc.) this weekend and then we will reloom it.
#40
did you eliminate the mazda OEM key chip security thing?
