Colorado lsx
Old 07-21-2012, 11:20 PM
M_O_Z's Avatar
Default Colorado lsx
I am putting a lq4 in my Colorado. I need computer pinouts for a 5.3 trailblazer 4wd, a Ls2/auto gto, 01 2500hd silverado 4wd and 04 3.5 Colorado 4wd. I wish I had AllData for this thank you if you can help.
I have 3 different harnesses I have to swipe pieces from lol.
Old 07-21-2012, 11:55 PM
Black98s10's Avatar
A 6L in a colorado? Please take pics of it, maybe a build thread.
Old 07-22-2012, 12:18 AM
M_O_Z's Avatar
I need to build my harness first. I have enough harnesses to make one. I just need pinouts of the computers. I blew one inline 5 up. I'm not looking to blow another. So I finally found a lq4 for 600 bucks complete. I have to come up with fuel rails from a Ls2 and injectors from a ls3. Putting a 212/218 lsa 114 can in it with a high volume oil pump. Once I get the harness done I can put the motor in.
I want to get the v8 swap done first then move onto the solid front axle.
Old 07-22-2012, 02:34 AM
mcdonald77's Avatar
you need only the ecu pinouts?
Old 07-22-2012, 06:41 AM
M_O_Z's Avatar
Pretty much and the tcm.
Old 07-22-2012, 10:55 AM
mcdonald77's Avatar
give me your email address and what year for the trailblazer?
Old 07-22-2012, 12:02 PM
M_O_Z's Avatar
Pepperfire2003@gmail.com. What I'm trying to do is build a harness like the lq4 setup but be running Ls2 electronics. Year on the trailblazer shouldn't matter but it has to be a 5.3 and 4x4 not awd.
Old 07-22-2012, 12:19 PM
mcdonald77's Avatar
I emailed you 4 ecu pinouts for the 4 different trucks.
Old 07-22-2012, 01:38 PM
M_O_Z's Avatar
I got them. Thank you. Now a question for you about the fuel system setup on your Jimmy. You used a Corvette fuel filter setup and took your return style setup to returnless. Trying to understand how you set it up by looking at your pics. I have to go to returnless as well.
Old 07-22-2012, 01:59 PM
mcdonald77's Avatar
It's pretty simple. I got rid of all fuel lines going from the old filter to the intake. Then used AN fittings to plumb the feed and return line to the vette filter/ regulator.
Old 07-22-2012, 02:30 PM
M_O_Z's Avatar
So your double filtering the fuel? The supply is the bottom and return is the middle?
Old 07-24-2012, 11:33 AM
M_O_Z's Avatar
Question for y'all. What are the differences between the gto tcm which is a t42 and the 05-06 trailblazer 5.3 tcm which is also a t42.
Old 11-22-2012, 03:56 PM
M_O_Z's Avatar
Old 01-18-2013, 12:48 AM
M_O_Z's Avatar
Motor is going to get compression bumped up with ls2 pistons and rods along with 799 heads. Going to finish tear down and get motor tanked.
Old 01-18-2013, 12:58 AM
M_O_Z's Avatar
Small scale salvage yards of parts
Quick Reply: Colorado lsx
