LM4 dip stick options?
Got a 2004 Buick Rainier all aluminum 5.3L LM4 (62K miles) and the 8th digit is P and the oil pan has the proper hole across it.
Plan to put it in a A body car.
The oil dip stick goes directly into the engine oil pan, there is NO oil dip stick hole in the block..!
Plan to use GM muscle car oil pan kit.
What are the dip stick options?
Thank you
Thank you
The kit should come with a dipstick. But it goes in the block IIR for that pan. There should be the hole in the block with a plug in it. Just knock plug out and run the reg truck dipstick. If it doesn't have the plug, just drill flange in block for it.
look through this thread.
http://www.carcraft.com/howto/ccrp_0.../photo_05.html
do you have a similar plug you can remove?
I am in the same boat but did not examine it closely yet.
