View Poll Results: Which k-member do you prefer?
Voters: 78. You may not vote on this poll
Fox LS-swap k-member options...
#101
Any luck on the new mounts yet? I ordered my Team-Z k-member last week and it should be here Tuesday. Was just curious what the status is on the mounts. I haven't ordered them yet because I wanted to wait and see what you come up with. I needed the k-member to get the car back on 4-wheels, so I went ahead and ordered it and the C/C plates. Thanks!!
3 months later and he is still telling guys to use the truck pan when he knows theres a problem with it...
#103
For those guys with a aje kmember can you pull the oil pan with the motor bolted in? Only reason I asked is I'm going to be putting a turbo in and Im not sure if what side I'm going to run it on so I'm not sure where the drain is going yet
#104
Don't think so. If not for the pickup maybe, but I just don't think it would slide out....that being said, I plan to tap my pan with it in place then just flush it super well with cleaner and oil. I think with a good amount of grease on the drill bit it should catch most of the shavings...we will see!
#108
My car has the ls1 pan, my dads 5.3 we used a truck pan, he hit a pot hole and busted the pan and the transmission case , so I got another truck pan and shortened it up so the factory K member was flush with the pan, it holds about 4 quarts of oil now
#110
With Tim's (Grey86Hatch) mounts the CTS-V oil pan worked perfect with the Team-Z K-member. For at least one person that will always come in here and gripe about how bad they think Team-Z sucks, and that you have to spend extra money on mounts, and buy a $500 oil pan, I'll go ahead and cut that off right now. I definitely don't care for the Team-Z mounts, and they definitely need to be redesigned. Tim's mounts were less than what I paid for the Team-Z mounts. If I would have skipped the Team-Z mounts to start off with I would have actually come out cheaper. So that cancels out the extra cost argument.
Like I said, the CTS-V oil pan fit PERFECT. Here are a couple of pictures (which are very hard to take by the way lol)
Just for reference, I tried different sockets until I found one to fit in between the oil pan and the K-member. Ended up with a 5/8" socket, which has an outside diameter of .85".
The pan tucks up behind the K-member a whole lot better than the truck pan did.
Its about 3/4" below the bottom of the K-member
So for anyone that has been wondering, questioning, doubting, etc.....YES THE CTS-V OIL PAN WILL WORK WITH THE TEAM-Z K-MEMBER!!! lol
It will probably even work with the Team-Z mounts with a little tweaking, but would be too close for comfort for me. So my recommendation is pass on the mounts that Team-Z sells and either fab your own, or find someone to make you a set. As I've said before, I've always been VERY pleased with my all the Team-Z products I've had before, and also love this Team-Z K-member. The quality of the construction, welds, etc is top notch. I'm sure they will get this mount situation lined out at some point.
#111
thanks for the insight- im not happy about the team mount fitment and the truck pan only setup.
Ill PM grey86hatch about some mounts.
#112
Yes,this is the route I went.i bought there upper spring perches because I didnt want noise issues.be fore warned,the springs are no fun to put in
#114
#116
Well we finally got a block, heads, oil pan and headers, Manual rack and steering shaft, and most important thing TIME! We built the K member to fit the LS/LSX block with the stock F body pan! this is the first one out of the JIG.
It is a complete re design so people can use the F body pan, we will have a TH350 and power glide Cross member next week! The K member will be an LS specific K member and should work with any pan!
#117
Well we finally got a block, heads, oil pan and headers, Manual rack and steering shaft, and most important thing TIME! We built the K member to fit the LS/LSX block with the stock F body pan! this is the first one out of the JIG. ...
Dumb question but will a power rack/steering shaft work as well?
Tipsy
#119
here is my UPR setup with a cts-v pan...steering rack clears by over an inch and the pan sits about a half inch below the k member... my only complaint is that it puts the motor close to the firewall...it doesnt touch when its leveled out. i have yet to fab up my th400 crossmember
price was hard to beat for me being a dealer for them.
