Project-89 Coupe LSX Re-swap, now going turbo
Old 03-11-2013, 07:38 AM
  #121
95civic2005's Avatar
Well yesterday was a decent day. Got the turbo mounted and hotside piping done. Going to order the coldside piping today and hope to finish things up next weekend for the most part. Gotta give all credit to my buddy Josh (91lscoupe) for fabbing this up!
Old 03-11-2013, 09:32 AM
  #122
club_xcursion's Avatar
are you going to add any bracing to support the weight of the turbo. i bought a t4 flange that was extended so i could bolt it to the car but i have to run flex pipe off the headers.
Old 03-11-2013, 11:28 AM
  #123
There is actually a mount for the turbo on there to support the weight of it. Can't really see it tho, it mounts to the bottom and outside Of the frame rail. I didn't get a pic of just that.
Old 03-11-2013, 07:06 PM
  #124
91lscoupe's Avatar
Lol I knew someone was gonna ask that, should took pics of it, turbo actual sits on a mount the piping basically supports nothing.
Old 03-11-2013, 07:07 PM
  #125
91lscoupe's Avatar
We are also putting a flex joint in next weekend and putting wastegate on, just didn't have them there this weekend
Old 03-12-2013, 12:22 AM
  #126
bakomack's Avatar
I'm in the middle of my turbo in my fox. What are you going to do for your return line?
I used a -10 and a 90 and tapped on the passenger side of the front cover between the balancer and the edge but I'm worried the stock balancer might be too big and catch the edge of the 90. So I'm thinking of looking into a under drive pulley that doesn't cost an arm and a leg
Old 03-12-2013, 03:20 AM
  #127
Blk2kSS's Avatar
nice build! I love a nice LSx/notch combo!
Old 03-12-2013, 07:36 AM
  #128
what size pipe was used for the crossover? asking bc im going to run 2 1/2 so i bought some flex that was 2 1/2 but the inner diameter was stepped down alot bc of the flex. im thinking about going to a 3 in flex
edit: nevermind, apparently i bought some cheap flex. just ordered some new ones.
Old 03-12-2013, 08:52 PM
  #129
91lscoupe's Avatar
Were gonna run return line either in pan or front cover, and we used 2.25" crossover
Old 03-14-2013, 06:47 AM
  #130
^^ Yeah what this guy said! Should have everything here Saturday except intercooler piping to finish the turbo kit and DP/exhaust. Not going to be able to get over to work on it until next Sunday tho, this working 7 days a week **** is cutting into getting this car done!
Old 03-14-2013, 07:08 AM
  #131
87lsttop's Avatar
very nice fab skills.Its a pita getting all that crap to fit in there the right way.
Old 03-25-2013, 07:05 PM
  #132
91lscoupe's Avatar
Bro y ain't pics of yesterday progress posted, man city boy u slackin lol
Old 03-25-2013, 08:33 PM
  #133
My bad hillbilly! I'm a busy guy what can I say. Here ya go!
Old 03-25-2013, 09:09 PM
  #134
aknovaman's Avatar
Got a paint code for that color or what did it come on originally?
Old 03-26-2013, 06:48 AM
  #135
Toyota Speedway blue, paint code 8p1.
Old 03-26-2013, 12:04 PM
  #136
jfisher's Avatar
Are those the hooker cast manifolds?
Old 03-26-2013, 01:19 PM
  #137
Cobra4B's Avatar
No... Hookers don't have those "nubs" on them. I just purchased a set for the Panoz.
Old 03-26-2013, 02:50 PM
  #138
91lscoupe's Avatar
stock 6.0 manifolds from autozone.....
Old 04-02-2013, 09:16 PM
  #139
89_camaro's Avatar
did u keep the stock oil pan or get an after market one they seem to sit very close to the ground? also what crank pully are you using? thanks
Old 04-03-2013, 09:32 AM
  #140
I'm using an fbody oil pan, which has pretty good ground clearance. Most people use fbody or cts-v pans from what I've read. And the Crank pulley is a Summit racing UDP.
Quick Reply: Project-89 Coupe LSX Re-swap, now going turbo
