Alt. bracket help!!
Old Sep 7, 2012 | 01:03 PM
1970 LSCamaro's Avatar
Angry Alt. bracket help!!
Hi guys, I am working on my 6.0 to go in my 70 Camaro. I DO NOT have power steerng or A/C. I am needing to know what is a good way to install my alternator. All the belt systems I am finding (March, Pace, etc) are like $900 and up.....I dont wanna pay that much. Alot of the info on here I have found deals with either having A/C or power steering or both. Where can I get a nice looking setup for my motor? I don't mind paying some, but not my whole budget. Do any of you know of any links? Thanks
Old Sep 7, 2012 | 01:18 PM
garys 68's Avatar
Kwik Performance
http://kwikperf.com/
Old Sep 7, 2012 | 02:47 PM
Originally Posted by garys 68
Kwik Performance
I seen them, but I dont like the look of the alt being higher than the intake. Thanks non the less. Anyone else???
Old Sep 7, 2012 | 06:22 PM
bronx_peanut's Avatar
Try this from Holley. http://paceperformance.com/i-9521565...ce-20-135.html
Old Sep 7, 2012 | 07:02 PM
Bo185's Avatar
The A/C runs off separate belt and can be deleted easily.
You could reroute with a different belt and delete the PS pump and run the stock truck bracket easy enough and it would be pretty much way cheaper. But the alt would be higher. You could mod that bracket to lower the alt as well.
Not my picture just on off google.
Old Sep 7, 2012 | 11:56 PM
TX RED's Avatar
I'll sell you mine
Old Sep 8, 2012 | 06:25 AM
Originally Posted by bronx_peanut
I am kinda liking the ones from Holley....I think I will call them on Monday to get more info and pics.
Old Sep 8, 2012 | 08:16 AM
6t7gto's Avatar
This?...
http://www.retrorat.com/2012/05/lsx-...nator-diy.html
Old Sep 8, 2012 | 01:47 PM
Originally Posted by 6t7gto
DUDE!!!!!! That is the exact **** I was lookin for!! Thanks a ton.
Old Sep 8, 2012 | 04:46 PM
tmcmillan5's Avatar
TX RED why are you getting rid of it & How much? Tony
Old Sep 10, 2012 | 11:21 AM
cruisin'73's Avatar
Default Easy and Cheap
Here is what I put together to run my alternator for my 73' Nova swap. Your 70' would be pretty similar on space constraints. I had the bracket laser jet locally. Its not as pretty, but it works!
Old Sep 10, 2012 | 08:39 PM
protracracing's Avatar
What bracket is holding the Alternator off of?Is that a truck alternator?
Did you happen get more them one bracket made?
Thanks
Dennis
Old Sep 11, 2012 | 07:49 AM
cruisin'73's Avatar
Default Custom Bracket
Thanks
Dennis
Yes, that is a 140Amp truck alternator, craddled in a stock F-body bracket. And since I do not need the idler pulley I shaved that arm off the bracket.
Because I am running the truck water pump, crank pulley and tensioner I had to create this bracket to space the F-body bracket 3/4" further away from the front plane of the engine to line up with the truck belt spacing.
Unfortunately, I did not have any more brackets made. But I will shoot you a PM and we can figure out details to have another one made.
Old Sep 11, 2012 | 09:03 AM
Crazier's Avatar
IF you have room to mount it low on the right side, check out my l33 valkyrie thread. I put mine together for like $60, It uses the stock F body bracket and the same bolt holes on the block that the F body uses, you are using the 6.0 so you would need to drill and tap one hole ( I think) . IF it were me I would have it tapped as I am no good at keeping things straight, plus, I would probably put a helicoil in it right from the beginning, I don't trust aluminum threads, and if you have to mess with it I'd go that way the first time.
Bottom line, alternator mounted for $30 (if you can find a bone yard part) $60 (if you tap it yourself) $100 if you have it drilled and helicoiled by some one else, and if you do use that set up and have any questions let me know, It really was easy once I had all the part numbers and found the bolts.
Old Sep 11, 2012 | 06:17 PM
Crazier's Avatar
https://ls1tech.com/forums/conversio...machine-5.html
page 5 shows it and lists the part numbers.
Old Sep 11, 2012 | 06:33 PM
Thats the way I am gonna do mine, Thanks
