Harness question
Old Sep 11, 2012 | 09:15 PM
souljaboy9768's Avatar
Default Harness question
I'm working on my 68 camaro I got everything fitted to put the motor in.
I have a donor car an 02 camaro ls1/t56
Can I use the whole harness?
Do I need to take the harness somewheres to get it to work?
Do I keep all sensors on motor and tranny?
Another question was do I need a torque on for tranny?
Thanks sorry for all the question
Old Sep 11, 2012 | 09:44 PM
i r teh noobz's Avatar
You can slap the whole harness on, but it will probably look like crap. Best to rework it some to fit better, or to buy a pre-made swap harness from a sponsor.
lt1swap.com has great info on the harness. Its very simple to do.
Keep all the sensors you need. Some people delete the MAF, some keep it. Rear O2s, EGR, and EVAP stuff are also optional depending on your emissions laws.
Old Sep 11, 2012 | 10:23 PM
Emission is not a problem, maybe re work might be better.
I really don't want wires visible
Old Sep 11, 2012 | 10:24 PM
I don't need traction control do I?
Old Sep 11, 2012 | 10:25 PM
ABS module?
Old Sep 11, 2012 | 10:46 PM
Nope. Just the engine stuff. Unless you want the F-body dash. The engine and transmission harness should come out as a single piece.
I suppose you could try to keep the ABS and traction control, but that would be a ton of custom work.
Old Sep 12, 2012 | 06:47 AM
psiconversion's Avatar
LS1Tech Sponsor
You dont need the emissions stuff for the engine. For the transmission i would recommend you keep the reverse lockout and vss. If you are going to run it in closed loop, keep the MAF and Front O2 Sensor hookups.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Sep 12, 2012 | 09:14 AM
Thanks Jon, I'm new to this. Could you explain the close loop for me?
Old Sep 13, 2012 | 12:41 PM
LS1Tech Sponsor
Closed loop is when the PCM is getting feedback from the O2 Sensors to provide fuel and spark adjustments. This provides better driveability and fuel economy, typically. Closed Loop occurs when the engine reaches a certain temperature as well as a few other parameters.
Jon
PSI
__________________
Ebay Store
Old Sep 13, 2012 | 01:07 PM
superbean's Avatar
I've done a harness for a friend and reworked mine.. they work and were essentially free (minus cost for shrink tubing and solder).
However, unless you are very savvy with a DVOM, Checking for power and continuity, then I suggest letting someone do it for you that does it for a living. Spending the extra cash on a plug and plug harness from PSI will save you a lot of time, headache and worries. You could even sell your stock harness to recoup some costs. What's nice about PSI is Jon is on the boards all the time answering harness questions for no fee to the DIY type although he sells swap harnesses.. ironic? No just the best business out there for custom LSX crowd!
-Randy
Old Sep 13, 2012 | 01:20 PM
What kind of price am I looking at? Does it include harness for t56
Old Sep 13, 2012 | 02:09 PM
LS1Tech Sponsor
Soulja,
Cost for the harness is $499 and it includes the T56 Reverse Lockout and VSS hookup.
Superbean,
Thanks for the kudos! We do what we can.
Jon
PSI
__________________
Ebay Store
Old Sep 13, 2012 | 08:03 PM
Thanks Jon, I'll get with you soon
Old Sep 14, 2012 | 07:19 AM
LS1Tech Sponsor
Soulja, FYI the harnesses are in stock.
Jon
PSI
__________________
Ebay Store
Old Sep 14, 2012 | 07:24 AM
andysfbird's Avatar
i have the re-worked harness for my 67, and can take pics for you b4 i put it in if you like. What are you doing for gauges?
