Ignition switch problem
I have a 1965 Olds Vista Cruiser I'm in the process of installing a 04 GTO LS1/4l60e into and am having issues with making the ignition switch work correctly. Doing a search shows that adding a jumper between the start and run terminals would work but doing that will keep the starter engaged all the time. Am I missing something here or is there a better way. I suppose a relay could be used but there must be an easier way. Any ideas? Thanks,Hal
Are you trying to use the orig switch to energize a relay? If so you can go right to the bulkhead connector and make a jumper there. It is a bit messy, with the tar and all, but this is the same way you go if you want to run HEI in the early cars. Look at a factory wiring diagram for specifics. This is how I did my car. It all works perfectly, and you can strip out a bunch of useless wiring.
Just put in a aftermarket switch and be thru with it.......
Not enough info. What are you trying to do? Can't think of any reason to add a jumper between "start" and "run", "run" should be hot with switch in the"start" position, unless your switch is bad.
Jim
Jim
Yes.. first of all, what is the problem or issue. I'm with 454ragtop on this..
Why do you think you need a jumper between Start and Run.. ?
are you having issue with the IGN hot wires (Pink) staying hot while starting.. ?.. if so.. that is a common issue with some of these older GM cars.. some had a wire coming from the starter/solenoid to the coil to make sure the coil stayed hot or got full 12+volts... you need to find a wire that stays hot and doesn't get interupted going between Run => Start => Run.
The early GM ignition switches didn't have power to the coil in the start position and used the starter solenoid to jump to the coil during cranking. I need to have ignition power available while cranking but don't see any way to do it without adding a relay. Replacing the switch doesn't look like an option as this is a dash mounted switch with a unique bezel. Hacking up the dash isn't an option and the later switches typically were column mounted.
There were posts about adding a jumper but I really don't know how that will work without keeping the starter engaged when in the run position.
Thanks for the replies, Hal
Ok.. so you are trying to power the EFI and Accessories via the Pink IGN 12+volts..(PCM, Sensors, relays, etc) as the Key is turned to the Run (and Start).
What I did was took a Digital Volt Meter and check the wires coming from the Key to the Fuse box. With the Key on Run.. I check to see what had voltage.. then still monitoring, turn the Key to Start.. if it stayed Hot. .then I would tap into that wire to power a relay for all of the Pink IGN wires.
If it went cold.. move to the next wire.. I can't tell you which one to try (most likely Orange, Red or Pink ?)... as I don't have the wiring diagram for your car.
BC
BC
Thanks for the reply, that's the way I was going to approach it if I couldn't find a simpler method. With all the early GM hybrids on here I hopped someone had come up with a simpler way around this problem. Thanks,Hal
Wow, that's weird, didn't know early cars shut off "run" when in "start". I know they shut off "acc". I wonder if replacement switches for your car are still made that way? You could add a jumper, but it would need a diode in it, to only let the power flow from "start" to "run", and not the other way. On further thought, I think you have something wrong here. I recently installed an HEI in a 66 Impala, swapped out the ballast wire in the firewall connector to a reg wire, did away with the starter bypass, and it works fine. Are you sure you don't have a bad switch, or wires swapped to wrong terminals at the switch?
HTH, Jim
HTH, Jim
