New "LT" engine series announced to replace the LS series
Old Oct 25, 2012 | 12:45 AM
i r teh noobz's Avatar
Originally Posted by superdave84
because it's confusing and unnesessary. It's not hard to come up with something that hasn't been used already. SR Series. JQ Series. XA Series. See? Easy.
In 3 years when some of these things are out on the market, I don't want to have to dig through 400 Craigslist postings to find the "correct" LT1
I already have a hard enough time explaining why my LM7 isn't a "tree fiddy."
Old Oct 25, 2012 | 01:12 AM
gofastwclass's Avatar
I've been waiting on this, I see a lot of hot rod potential.
...as for the prior comment on unfriendly computers... Gen III computers used to be awe inspiring un-tunable magic boxes - until someone hacked one. Now everyone has a copy of HP Tuners or EFI Live.
Put simply, just after the first fence or wall was built a creative fellow invented the ladder. It's only a matter of time.
Old Oct 25, 2012 | 02:46 AM
Wnts2Go10O's Avatar
just.. lay off the caffeine. they recycled the LS series RPO code too. and the ZL1 code.
there was already an LS-6, LS-7, etc in the 60's.
Old Oct 25, 2012 | 05:19 AM
Pop N Wood's Avatar
more
http://www.enginelabs.com/engine-tec...n-small-block/
Old Oct 25, 2012 | 08:41 AM
superdave84's Avatar
Yeah? And what about the guys on message boards like this asking "LT1 to LS1 fuel lines?" Now everyone has to clarify everything over and over, and it's totally unnessesary. And I stated in the very first post that there were already LS engines decades ago....doesn't make the idea to name this series LT any less stupid.
Old Oct 25, 2012 | 09:07 AM
brewster240's Avatar
also, original ls and new ls are awesome.
old lt kinda sucked, so is the new lt...
Old Oct 25, 2012 | 01:46 PM
bigdog7373's Avatar
If it follows along with the LT series reputation then it shouldn't be around too long lol. I don't see this heap of over-engineering being any better than the Ls. They should have just updated the Ls series again. This new design looks overly complicated for no real reason or benefit. Now we have to take the entire top of the engine off to change an injector? And now the injector will be triple the price!
I really hope this thing is really awesome, powerful, and reliable for at least 200k miles, or else it wouldn't be worth dropping the Ls.
Old Oct 25, 2012 | 02:15 PM
you have to pull the intake manifold off to pull the injectors, its not that much more work.
do you change your injectors often enough that its a problem?
Old Oct 25, 2012 | 03:07 PM
bigdog7373's Avatar
Just think of all the **** that will be on/connected to the intake once the motor is in the car.
My car is carbed so i can't answer your last question.
Old Oct 25, 2012 | 03:52 PM
Wnts2Go10O's Avatar
anyone that converts this engine to carb needs to be hit with a rotting Carp.
Old Oct 25, 2012 | 04:40 PM
bigdog7373's Avatar
I said my currect engine has a carb! Lol. I wouldn't even think of putting one on this new motor. Hell I don't even like when they are on an ls motor.
Old Oct 25, 2012 | 05:56 PM
  #32
Wnts2Go10O's Avatar
i know u did just sayin, bd.
Old Oct 25, 2012 | 06:11 PM
  #33
decorative cover, throttle body, map sensor, maybe a vac nipple for brake booster.
doesnt sound like much to me.
Old Oct 25, 2012 | 06:14 PM
  #34
a lot of people seem scared of new tech.
im pretty excited about this. its still a cam in block pushrod motor, but has some great new tech mixed in.
whats not to love? again back to my bmw history, aside from early on issues which i doubt this motor will have, the direct injection did wonder for efficiency and performance.
Old Oct 25, 2012 | 07:59 PM
  #35
wildcamaro's Avatar
450/450 is pretty impressive when you have 50 more ftlbs throughout the entire rev range...
Old Oct 25, 2012 | 08:33 PM
  #36
1981TA's Avatar
It seems to work good for me. Gets 20-22 MPG in the highway too. Although, yes, I wouldn't mind a good EFI setup. The whole cold starting thing is a royal pain in the can. I'm with you in thinking anyone who carbs an engine like the future LT1 has to be smoking some serious weed.
Old Oct 25, 2012 | 09:09 PM
  #37
Snkebait95's Avatar
Seems pretty simple really. They basically moved the fuel rail and injectors under the intake and put the injectors through the head into the combustion chamber. Then worked their magic on the rest of the design.
http://gmauthority.com/blog/2012/10/...ustion-system/
Old Oct 25, 2012 | 10:45 PM
  #38
hookemdevils22's Avatar
the water pump is weird and the belt tensioner looks like they bought it from bmw.
Let's just hope the water pump isn't from BMW. 60k miles for a cooling system overhaul (at least for my E46)? Ludicrous.
If direct injection is scaring people, I'd steer away from diesels. They've somehow been doing it for... ohh 80+ years. At least the L-tee engine family still has pushrods. I'm pretty sure the entire hot rodding community's heads would literally explode if the General moved toward DI and OHC at the same time. I personally can't wait to shoehorn one in the Nova.
Old Oct 26, 2012 | 09:09 AM
  #39
bigdog7373's Avatar
Its great and all that they made this new engine. But what they really needed to do was make a smaller diesel to go into the avalanche, half ton silverado, tahoe, and suburban! How long are they going to let those trucks get crappy mileage with no option for a diesel engine!? Come on GM!
Old Oct 26, 2012 | 09:26 AM
  #40
LSX user's Avatar
450HP with a 200* cam with a 50lb.ft. torque gain. Amazing. These raised intake ports, almost into the valve covers, bleed HP. In typical Chevrolet launch mode we get the basic release and in 3 years we'll see 600+HP with a cam swap and headers! I'm an all motor fan so power adders don't mean ? to me. I'd like to see some flow numbers with these smaller 2.130 intake valves, although they are canted 2.5 degrees.
