Jeep Grand Cherokee steering box swap on a-body
The 3rd gen box is the best fit for a first gen F body. From what I've learned the jeep box turns much sharper then a camaro so the internal stops are not matched up. I'm sure they are both saginaw 800 type boxes, but you don't want your car to turn further then it's designed for.
yup I can confirm the jeep box doesn't work in a 1st gen Camaro/Firebird and not on purpose. I ordered a reman'ed box from AZ and got a 3 Turn L2L box that was ordered by application (88-92 Camaro Firebird) and got a jeep box which when mounted is extremely tight turning and also puts the angle of the box about 5 degrees higher than the rag joint coupling which made it almost bind when turning. Cant trust part store reman boxes, it should have been a 3rd gen box 2.25-2.5 turns lock to lock.
