Low Alternator for Low Cost
Old Oct 30, 2012 | 08:15 PM
djleighk15's Avatar
Default Low Alternator for Low Cost
So as the title reads im lookin to get my alt bracket lower for hood clearance and im on a budget...just had a baby so i gotta keep cost down. I have a bodydropped s10 that the 05 5.3 tahoe motor is goin in. already picked up a ls1 intake and fuelrails and a camaro waterpump. I was lookin at the kwik, speedway or dirty dingo kits but like I said the budgets is lower now so im lookin for more options...I dont have a p/s pump or alt yet so i can buy whatever is needed for what you guys suggest...any help will be appreciated.
Old Oct 30, 2012 | 08:17 PM
djleighk15's Avatar
and as you can see in the other post i am using power steering
Old Oct 30, 2012 | 08:18 PM
gofastwclass's Avatar
Several of us made our own, my build topic has a picture of mine. The_Merv made one for one of his cars. The only limit is your creativity and fabrication skills.
Old Nov 1, 2012 | 12:04 AM
djleighk15's Avatar
what are my options as far as changing the oem hermonic balancer, and p/s alt bracket? Like could I find a hermonic balancer off a f-body ls1 and p/s-alt bracket off same f-body..would that all work?
Old Nov 1, 2012 | 01:46 AM
wildcamaro's Avatar
You have to match the balancer to the all the other accessories as the truck, f body, and vette all have different spacing relative to the timing cover...so to answer your question yes...
Old Nov 1, 2012 | 12:59 PM
djleighk15's Avatar
perfect, thanks for the help man..I think that would be my cheapest route to go all oem camaro accessories
Old Nov 1, 2012 | 01:02 PM
ronnieforrester's Avatar
not sure about your P/S but this is what im doing in my fox w/o p/S
http://www.retrorat.com/2012/05/lsx-...nator-diy.html
Old Nov 1, 2012 | 01:57 PM
djleighk15's Avatar
Yea im using power steering so that wont work but I think im just gonna swap out the truck crank pulley and swap in the camaro one and just get camaro oem alt/p/s bracket
Old Nov 1, 2012 | 03:43 PM
-TheBandit-'s Avatar
Depending on what room you have, you can also keep the truck balancer and add spacers to the other accessories to bring them out from the block.
Old Nov 1, 2012 | 06:52 PM
djleighk15's Avatar
Can't use the truck alt/p/s bracket cause I have hood issues and I'm keeping stock hood for sure. That's why I was asking cause with camaro bracket will let alt clear hood. Guess yur saying I could run camaro bracket with spacer rather then getting new balancer pulley?
Old Nov 1, 2012 | 09:38 PM
racerrit's Avatar
F body acc. is ur best bet. low cost and it will all match up. Call LKQ and they can hook u up with the parts cheap
Old Nov 2, 2012 | 07:42 AM
10droped's Avatar
Your still going to have to relocate the alt, u can't use the alt. bracket it will hit the steering box. The power steering braket should work for you though.
Old Feb 23, 2013 | 08:43 PM
TDMKR496's Avatar
Does anyone know how thick the spacer would have to be to use a truck balancer with a F body alt. bracket??
Old Feb 23, 2013 | 11:34 PM
i r teh noobz's Avatar
I think its a half inch.
The truck alternator will fit the F-body bracket.
Don't forget that you're going to have to drill the extra hole in the block (not that its hard, I did mine in the car - twice).
Old Feb 24, 2013 | 04:51 AM
boostin01's Avatar
thats pretty much the same alternator location on australian ls1 2 and 3s, with p/steer pump above that.
australian ls2 and ls3 run a different balancer so accessories i assume are spaced differently though
Old Feb 24, 2013 | 08:10 AM
Gray86hatch's Avatar
Holley has a nice set of brackets that let you use a cheaper truck alt and space it to work with what ever balancer and water pump you have.
Tim
Old Feb 24, 2013 | 09:13 AM
fox12303's Avatar
Offset from F-body to truck is 3/4". You can swap pulleys on the waterpump to use an F-body pump with truck offset. F-body alternator may be very close to your steering box. If your truck block is iron I would go with an F-body alternator as it has a rear mount for better support. The iron block doesn't have the center mounting hole so you really need the rear support bracket, IMO.
